ATE calipers lightly dragging, ABS may actually be the issue?
  • 1point8litre
    • Feb 2014
    • 15
    Has anyone had an issue with reman ATE calipers not retracting enough and lightly dragging on the rotor? The pedal is also a longer than I'm comfortable with. The ABS system isn't active so I wonder if it has something to do with that? I'm using a known good E32 master cylinder and known good booster.
  • 82eye
    • Jan 2009
    • 2091
    how are the hoses and hard lines ? a crimped hard line or a collapsed hose can trap brake fluid creating pressure causing the brakes to drag.
    • 1point8litre
      • Feb 2014
      • 15
      I'll double check. The hoses are new, but the front lines are original. Maybe something is clogging it. I'm going to bypass the abs unit with a jumper line to see if that may be effecting it too.
      • rmdashrf
        • Feb 2014
        • 207
        have you inspected the brakes calipers and possibly considered rebuilding them? I learned recently that the caliper piston seal is one of the major factors in pulling the piston back.
        • Digitalwave
          is a poseur
          • 6299
          You're talking about a lot of potentially unrelated issues here.
          Dragging on rotor -- might need to be rebuilt
          Pedal longer -- you are running an MC not sized for your calipers. It is not the upgrade that the forums make it seem. Could be related, could just be tapered brake pads.
          ABS not active -- this is not related to either of the two above issues
          RISING EDGE
