Camber and toe
  • AndrewBird
    The Mad Scientist
    • 11898
    Originally posted by nando
    because the pickup points of the trailing arms are angled.
    http://www.e30m3project.com/e30m3per...rves/index.htm
    Ah, that's what I figured. I never really looked that close before.
    • E30Nova
      • 1546
      Originally posted by E30Nova
      Probably a dumb question, but is it even possible to adjust camber/toe with stiff poly bushings? I just adjusted my brakes yesterday and saw my rear tires were worn pretty bad on the inside so I swapped em to the front.
      I've got IE Stage 3 springs and every bushing has been replaced with AKG 75D. It was damn near impossible to do anything to those bushings, so I don't even know if it would be possible to adjust anything with them since there's so little give.
      Matt
      Anybody?
      Anybody have the camber/toe correction kit with poly bushings?
      Matt
      Matt
      I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
      Originally posted by kronus
      try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
      This is like a reverse build thread; it starts out nice and gets shitty.
      • X_WizarD_X
        • Jul 2005
        • 99
        Have them but the entire rear section is on saw horses waiting to be installed..
        And the bushing do not have to "give". You could in theory use solid steel bushings..It's the bolts that go through the bushings that adjust. The bushing's just slide within the weld on brackets.
        The Keystone Killers: for the Commonwealth!
        Member #18 of M42Club.com
        1991 318is Diamantschwarz Black
        1992 850i Calypso Red
        • Wh33lhop
          • 11705
          Anybody?
          Matt
          You will be fine. Adjusting the toe/camber will minutely affect the axis of the trailing arm bushing pins (bolts) vs. the trailing arms, but it will be by a trivial amount.
          paint sucks
