I feel like an Idiot CA
  • SwiftE30
    • Jun 2010
    • 998
    Has anyone had trouble fitting new control arms, specifically the ball joint that bolts to the strut? I cant seem to figure any solution out. Ive tried jacking it up but it just compresses the spring/shock. And i tried getting a press but i dont have the right amount of space or angles to make it work. Any advice helps. Thanks
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Can you get a grip with a few turns of the threads? That will pull the shaft into position.
    • SwiftE30
      • Jun 2010
      • 998
      No grip whatsoever. The stud barely comes through the ohwr side. And the CA' are lemfoerder so I don't think that is the problem.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Jack it up high, anti-seize on the shaft, and a BFH. Otherwise, I'd grab a micrometer and spec both the shaft and spindle hole.
        • SwiftE30
          • Jun 2010
          • 998
          Yeah im about to use a hammer. I have a micrometer and i checked the shaft and spindle hole. and the new shaft is exactly the same as the old one (original part, never been replaced)
          • SwiftE30
            • Jun 2010
            • 998
            No luck.
            • StereoInstaller1
              GAS
              • 22679
              All that is happening is your brand new balljoints don't flex easy like your old ones did.
              Line it up better and it will fit.
              Closing SOON!
              Thanks for 10 years of fun!
              • Dj Buttchug
                • Jun 2010
                • 7683
                Originally posted by stereoinstaller1
                all that is happening is your brand new balljoints don't flex easy like your old ones did.
                +1
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • StereoInstaller1
                  GAS
                  • 22679
                  lemme 'splain better: it is gonna be a pain in the ass, but it will line up.
                  Closing SOON!
                  • SwiftE30
                    • Jun 2010
                    • 998
                    I know it will line up, I just don't know how to force it in there. when I jack
                    up the CA into the strut it goes up a ways and them starts lifting the car. I'm thinking I need like a manual press or something.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Use some cribbing, and jack it until the strut hits the bumpstop if need be.
                      • StereoInstaller1
                        GAS
                        • 22679
                        I bet a little anti-seize will do wonders
                        Closing SOON!
