RX7 caliper and bracket Roll Call
    • 37833
    #46
    Originally posted by 2002maniac
    won't the turbo car need some buggbreaks?
    Damn it...
    Grover Beach, California
    BimmerHeads.com
    • Dissembler
      • Jul 2008
      • 153
      #47
      Originally posted by E30_pilot
      I also just got my spacers in to run Esm 008 16x9 et15 so I'll try to get pics in later.
      Did you ever fit those esm 008? Interested in those rims myself. What tire size are you running?
      • reelizmpro
        • 9558
        #48
        Anyone fit these behind euroweaves yet??? they are 15x7 ET24. I'm thinking I need a 8-10mm spacer.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • imwhyteyo
          • 1165
          #49
          will be putting the later style rx calipurs with my keskin kt1's real soon. 16x7.5 et20. im grinding off the mazda portion and step out too. will get as many detailed pics and info as i can.
          • 2002maniac
            • 4260
            #50
            Did you get them to fit the Keskins? I always loved those wheels. Be sure to post some pics!
            • graphikg
              • Jan 2008
              • 1614
              #51
              Originally posted by darrenforeal
              BTW do you happen to have extra fittings that I would need to use to get the E30 brake lines to fit the rx7 calipers?
              I am also interested in this info. And would these brakes fit with the TRMotorsport C1 15x8s?
              • Mullet Bullet
                • May 2011
                • 904
                #52
                Bump, looking for the same info if the tr c1's will clear in 15x8
                Originally posted by nwvb bmw
                That guy is going to lock you in his basement and make you ware a little pirate costume.
                • 2002maniac
                  • 4260
                  #53
                  I believe the trm 15x8 were confirmed to fit with light grinding of the fluid passage on the caliper. I still have line adapters if anyone needs them.
                  • tommyp
                    • 112
                    #54
                    From what i gather the spoke design on a set of BBS RM's would be a problem, correct? 15x8 with a 13 mm offset?
                    • 2002maniac
                      • 4260
                      #55
                      You are correct. Those wouldn't be ideal.
                      • johnjohnsons54
                        • Mar 2012
                        • 228
                        #56
                        Does anybody know if 16x9 ESM 002 et 10's would work? I'm guessing I'd have to run spacers which would push the wheel out way too much.
                        ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
                        In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
                        I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
                        • frankie591
                          • Feb 2012
                          • 545
                          #57
                          Has anybody tried the 16x7.5 throwing star reps? I know they fit a massive bbk behind them, but I don't know if the rx7 setup requires more clearance than the willwood calipers.
                          • iansane
                            • 1343
                            #58
                            I was going to be putting these brakes on tomorrow (just got the adapter brackets in yesterday). I picked up new rubber parts store brake lines and they are not bubble flared, they are regular double flare? This seems odd to me? Do I not need the adapters? Has anyone come across this before?
                            84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                            • einstein57
                              • Jun 2007
                              • 10780
                              #59
                              my esm 7.5 002s required a 3mm spacer. Not sure how different the backs of the low offset 9s are.
                              www.gecoils.com
                              • polowildhorse
                                • Apr 2012
                                • 2
                                #60
                                Hello everyone. I am new to r3v. I wanted to know if my alpina 16x7 et28 wheels will clear the rx7 BBK or if I will have to get spacers. I am really interested in the kit. https://sites.google.com/site/e30bra...30_RX7_CORRADO
