IE BBK installed, finally :)
  • fporro
    • 1860
    man, finished it.
    had to find a master cylinder since my oem unit went bad after BBK install.
    swaped it with one from a 90 750iL, straight swap, 25mm unit. love it :)
  • Mot
    45 toting redneck
    • 4018
    hows the improvement over normal e30 brake setup with say slotted rotors and good pads?
    • Kilomph
      • Oct 2004
      • 599
      This may be a stupid question, but is the BBK from IE used?
      • fporro
        • 1860
        IE sale new ones and I think this kit was phased out since they offer an updated kit..
        I bough it used from some guy in one of the other boards.
        • JasonH
          • 434
          Which sway bars are those?
          • fporro
            • 1860
            IE's 25/22 combo.
            i asked in another board, but can you tell me your car hieght measured at gaps between fenders to body as well as atop anti-ding strip on door.
            car is ready for an aligment so looking for camber, caster and toe in readings for a street set up.
            it' s an 87 325ic, and here's the suspension set up...
            thanks,
            Frank
            • cahomey
              • Mar 2004
              • 1201
              Originally posted by fporro
              IE's 25/22 combo.
              thanks,
              Frank
              5º positive camber, turn your m3 bushings inside out, and finally retract your tierods in as far as they go. Ultimate street setup.
              "It's like a koala bear crapped a rainbow in my brain."
              R.I.P. Harry Goz aka. Captain Murphy
              "My ride, My ride, she don't beg, steal, cheat, or lie,
              My ride, My ride, and our relationship is classified."
              • fporro
                • 1860
                wow, never heard of such radical setup, I'm still new at this.
                thanks.
                • bmwdude
                  • 268
                  I second that question. How is the improvement over a modded stock setup? Is it worth the $1000.00 for a new IE BBK setup?
                  • fporro
                    • 1860
                    thre's defenetly an improvement over oem based on stopping distance.
                    then again i'm runing heavy 17" and never took the time to actually measure distance.
                    oem 14's onto oem tires weight 34 lbs.
                    found a 17 rim with 205 40 that came in at 36
                    but i'm running 215/45 and they are 8 lbs heavier than oem.
                    maybe there a number cruncher out there that can come up with the formula for inertia x whatever
                    can someone with cabrio and oem brakes post stopping distances from 60 to 0 and perhaps a bit higher speeds too ? :oops:
                    not parking lot but on actual paved road please.
                    I'll take it to my local deserted canyon and measure what i get.
                    • fporro
                      • 1860
                      What kind of calipers are used in IE's kit? They are so ugly but I am sure they do their job well.
                      Corvette C4 calipers ...
                        • 34839
                        thanks.
                        I think he's kidding..
                        • fporro
                          • 1860
                          i'm as dense as fog, heheh :)
                          • fporro
                            • 1860
                            New rims for it :)
                            • ak-
                              • 12422
                              You been saving for 6+ years lol?
                              1991 325iS turbo
