Remanufactured Brake Calipers
  • Luis325
    • 3847
    Im thinking of buying new or remanufactured calipers for my vert.
    Any tips on where to get them?
    Thanks
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • drumad
    • Aug 2009
    • 1700
    Rockauto.com
    replaced all my calipers with theirs.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
      Why not rebuild the calipers you have? Unless the piston seal surfaces are corroded the calipers can be rebuilt easily and cheaply and the result will be at least as good, if not better, than remans.
      • z31maniac
        • 17566
        ^This.
        I bought some rebuilt ones from BMA and while they worked, the "paint" if you want to call it that, came off the calipers the first time I washed the car, then instantly started surface rusting.
        I'd rebuild them yourself, and when they are apart, have them powdercoated so they will continue to look good for years into the future.
        www.gutenparts.com
        • Luis325
          • 3847
          OK Thanks guys!
          Any idea on what parts i need to buy besides the rubber seals for a complete rebuild?
          Thanks
            • 34839
            rebuilts are surprisingly cheap - it depends on how you value your time. Rebuilding a caliper is super easy, but so is buying one for $40 and bolting it to the car.
            • Luis325
              • 3847
              whats the difference from semiloaded and loaded??? price varies allot...?
              • Luis325
                • 3847
                ^^^ anyone 
                • mr2peak
                  • 2388
                  Loaded usually comes with pads.
                  Where can I get a caliper rebuild kit?
                  Drive it hard. Maintain it well.
                  A Topless Memorandum
                  • KenC
                    King of Kegstands
                    • 14396
                    Blunttech for all the parts.
                    Rebuilding them is ridiculously easy. They're all single piston. Get new guide bushings too.
                    Originally posted by Gruelius
                    • blefevre
                      • Dec 2008
                      • 4287
                      Any opinions on reman brands? There seems to be a ton.
                      - E30, DSM, Golf R, Mazda 3 Skyactiv
                      • browntown
                        • Jun 2004
                        • 3524
                        They should all be fine, there aren't a lot of parts in our brakes. I replaced all of mine with remans, but holy cow did they surface rust instantly.
                        • jrobie79
                          • Mar 2006
                          • 2526
                          autopart international has reman'd girling calipers, i think they were 48 bux in massachusetts, dont know if they have any other locations, and I'm pretty sure they dont have an online ordering setup, but they have pretty good prices and service brick and mortar
                          1991 318i ---- 308K - retired
                          • Jand3rson
                            • 37587
                            I'm going to be rebuilding mine, mainly because I just want to have the experience of doing it. I already know how to bolt them to the car.
                            • Gruelius
                              • Oct 2009
                              • 298
                              pins bushes seals
                              im not sure if the carrier wears on girlings (i have ate's)
                              RIP 84 323i coupe 5spd w/ 14psi
                              89' 318i
