CAB swap w a vice
  • bastianshaw
    • Jan 2007
    • 2210
    CAB swap w a vice
    Like to hear from ppl who have swapped their cab in n out of the lollipops using a vice
    How did you do it?
    recommend?
  • KenC
    King of Kegstands
    • 14396
    You can probably do it. You'll need a piece of pipe or something to get the old one out.
    Originally posted by Gruelius
    • Wh33lhop
      • 11705
      I threaded a hack saw through my old ones and cut them out, then used a big bench vice and some oil to get the M3 CABs back in.
      The vice was not very happy. Wound up bending the handle about 90 degrees cranking down on it. It was kind of an old POS though.
      paint sucks
      • bernzpeed
        • 3917
        told you.
        insert the handle inside a piece of long pipe like from a floor jack could help give you leverage.
        89 E30 S52
        Transaction Feedback.
        • Wh33lhop
          • 11705
          That is exactly what I did and that is why it bent.
          paint sucks
          • bastianshaw
            • Jan 2007
            • 2210
            told you.
            lol yes, you did...maybe ill keep looking for a reasonable shop
            • bernzpeed
              • 3917
              nothing beats a hydraulic press.
              89 E30 S52
              • bernzpeed
                • 3917
                there's still the washers and nut thing. i've seen it done in here. try looking for jaywood's thread or better yet SimonS with his Zen and the Art of E30 Maintenance
                89 E30 S52
                • Bearmw
                  • 1323
                  Just put in M3 bushings in my girl's 88is using a vise. Cut out the old ones with a reciprocating saw. Cleaned up the mount with some sand paper to smooth it out and put a good amount of grease on the bushing and on the mount and pressed it in with the vise. Had to make sure the bushing was going in straight but it went in without too much force and I also used an extension handle on the vise but overall it was an easy method with no damage to parts.
                  Did this without removing the control arms from the car. I just used a small puller to pull the old bushing off the control arm. The hardest part was getting the new bushing on the control arm but with some soapy water and brute force the entire job was less than 2 hours total.
                  • george graves
                    • 20003
                    Originally posted by Matt-B
                    • Bearmw
                      • 1323
                      Forgot to add that to get the bushing centered in the lollipop I used a circular spacer from my harbor freight wheel bearing kit just larger in diameter than the bushing to press the bushing so it was even on both sides.
                      • StereoInstaller1
                        GAS
                        • 22679
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • Bearmw
                          • 1323
                          Luke why didn't you post that earlier and save us all that typing:up:
                          • bernzpeed
                            • 3917
                            thanks, Luke.
                            89 E30 S52
                            • bastianshaw
                              • Jan 2007
                              • 2210
                              Thanks!
                              YOU DA MAN!
