So 190$ for camber and toe?
New rear adjustable Camber/Toe design.
Do you guys have a set for us 2002 guys? Can I just use the e30 set? I compared the 2002 and e30 eccentric set ups and they are almost the same. I think the 2002 set up just had a bit more adjustment.
Edit:
Just checked the store, and yes you guys do. I will be picking these up for my rear sub frame. I need a set of strait control arms for the back. Mine are bent :(sigpic
Very nice. These look far more likely to stay in place and far easier to adjust.
I have set of the old type. I installed them with the bolt near the subframe bushing snd tried it again with the nut near the subframe bushing. Both were a bear to adjust and the subject of much cussing. Also, one of the toe adjusters just absolutely would not stay fixed until I modded the darn thing.
If this kit works well, it will save a person many hours of frustration.
I crunched my race car a couple weeks ago so am building another. If my old subframe is bent I'll be buying this kit and installing it on the new subframe.www.Gress.org
All that is necessary for the triumph of evil, is for good men to do nothing. -E. Burke
NASA SpecE30 #6, BMWCCA #161
sigpicComment
The feedback has been nice so far.
Be interesting how you chose to reinforce the setup Chris.
Kevin of DTR Performance just put them on his One-Lap E30 and was kind enough to take some pictures.
The opposing toothed lock-bracket in which the bolt threads into has been heat treated to be strong enough to withstand the forces it will encounter, however it looks like Kevin threw on a lock nut just in case (for those that would like to do that, it's a 12x1.5 stover locknut)
Seth at Midnight Oil Motors in San Diego has them on a few Spec-E30 cars as well.
*one note is that on the Z3 the added adjuster length get's pretty close to the underbody, on those they've just ground down the edges for a bit more clearance.Last edited by SkiFree; 02-09-2012, 01:25 PM.Comment
These look solid. Whats the max degree of camber these can offer?Comment
So this has peaked my interest. Would using these in conjunction with a 12mm raised subframe be overkill?1985 M10b18. 70maybewhpoffury. Over engineered S50b30 murica BBQ swap in progress.
Originally posted by DEV0 E30You'd chugg this butt. I know you would. Ain't gotta' lie to kick it brostantinople.Comment
I've yet to see someone come even close to maxing them out. To get a better perspective I snapped a picture of the eccentric and the posi-lock brackets. Actual maximum degree of camber/toe is going to vary on where the welder puts the brackets on and if the arms are already bent, etc.
In terms of max adjustment it's going to be overkill, however what you might be looking for is going to be relatively small incremental changes as the short subframe bushings (while a good idea) do not automatically equal perfect camber/toe. Frankly both the eccentric and posi-lock style adjusters will both do what you want.Last edited by SkiFree; 02-17-2012, 10:39 AM.Comment
