Can't Get Control Arm Off
got it almost threaded off. But is now stuck at the top of threading. Nut is about 1/4 off the stud. Still twisting, I have ball joint jacked up with the pickle. nada2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
Put enough pressure on the bottom of the ball joint with the jack to cause the jack stand on that side to not be supporting the car. Don't lift that side off the jack stand, just make it loose and not taking weight.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
(Daily Driver)
KW V2 Coilovers
I'm gonna have to do this next weekend....Bentley manual makes it seem very easy..lol.
I bought the ball joint separator tool from Harbor Freight...also bought a puller to pull the bushing off the arm as i'm replacing it with AKG poly offset bushing. Any other tools? I guess i have to go buy a 22mm open end wrench?Comment
its easy. you put the jack under the ball joint, whack it 3-4 times on the side with a BFH then boom, it comes right off.
OP, get some visegrips and hold the fucking thing from spinning, you are replacing it anyway.
i usually press the bushings out of the loli popComment
