Can't Get Control Arm Off
    the nut on the sub frame for the inner ball joint should come off if you nail with an air gun. the trick is to get it the first time to prevent it from spinning. throw the jack under the joint so that it lessens the chance of the shaft from spinning with the nut. if you get that far then take an air hammer and be easy on it. you can knock the shaft through with that. I've seen my bmw tech buddies do it this way. If you can't you might want use the pickle fork but you'll most likely trash the boot on the joint and will need replacing then. the last thing, remove the sub frame; at least you'll have a chance to clean it, have a clean working area to remove the control arms. I've done it all 3 ways.
      This is the damaged one you're trying to get off, right? Just use a pickle fork. It'll destroy the boot, but whatever.
      Originally posted by Gruelius
        Yeah I have new arms on the way... so I dont mind destroying them
        Its hard to hammer them form the top, not much room.
        I was thinkign Id thread the nut on a little then hammer on the extension
          They bend, taking all of the shock out of it.
          Pickle fork and a 3lb maul. Works every damn time.
          Leave Me Transaction Feedback
            This definitely, does it for me every time.
              Will rent a picklefork from autozone, or a buddy, then
                22mm Pickle fork for removing the control arm from the subframe.
                Hammer the fork in place, hammer the fork down, and bingo. Easy. Use a decent amount of PB Blaster too.
                The BMW Bible: http://www.realoem.com
                2011 328i xDrive Sedan - DD
                2002 530i - sold
                1994 525i - gave to dad
                1991 345is (M102 Swap) - sold
                1985 325e - sold
                  hey what size socket is needed for the ball joint closest to the middle of the car. The one on the subframe?
                  2014 Alpine White 335i MSport
                  (Daily Driver)
                  Full Mperformance Aero
                  KW V2 Coilovers
                  VRSF Catless Downpipes
                    and whats the easiest way to get to that nut?
                    (Daily Driver)
                    KW V2 Coilovers
                      22mm. Extensions for drivers side, Stubby wrench for the passenger side.
                      Now get your nut off!
                        having extreme troubles with getting the socket on the drivers side. There seems to be a metal peice in the way. Anyone?
                        (Daily Driver)
                        KW V2 Coilovers
                          I use a 22mm box end wrench. I bought a cheap ratchet one from Harbor Freight and do it from under the car.
                          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                            yes, that metal piece is the shield for the motor mount. Unless that is missing you are speaking of the motor mount bracket itself?
                            other option like mentioned...
                              okay, well I had a 22mm box end wrench on there, a pickle fork hammered in, and a jack underneath the ball joint. I was able to move the nut, but I think it's twisting the joint around, rather than the nut on the thread. I have used a ton of PB and still no use.
                              (Daily Driver)
                              KW V2 Coilovers
                                Put a jack exactly underneath the ball joint to stop it from turning.
                                Sent from my HERO200 using Tapatalk
                                89 E30 S52
                                Transaction Feedback.
