Ohhh a bushing goes there? Whats thaaaaat?? =( Poof!
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    Well yeah. So, my left CAB inner delrin sleve that the CA slides through decided to go on strike. I havent been driving my car for the last couple days because I was beginning to hear/feel a nasty knocking sound when I would apply my brakes. Im kind of surprised that the wheel didnt wobble like it did when my stock rubber bushing was destroyed, it would just THUNK when I apply the brakes and again when I removed my foot. I really dont know if I should be surprised or not either. The side that blew up this time is the same side that was all messed up earlier with the stock bushings...thats why I replaced them. I didnt sand anything either to make it possibly remotely abrasive, and the old rubber ones broke down in the webbing not in contact with the CA anyway to mar it up.
    What wonderful luck, huh? They have MAYBE 3000 miles on them :(. The other side is perfect....
  • mrsleeve
    • Mar 2005
    • 16387
    dude, eye ball arms. you wont have that prob
    Originally posted by Fusion
    William Pitt-
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Who knows, they have a delrin sleve too (if you're referring to THR) whatever scrubbed this one away would do it to anything else :/ Im not going to go full solid mount though, even the THR ones would probably be too harsh IMO. Looks like ill be replacing the CA though too, it seems like it has been marred up now.
        • 34844
        I'll stick to rubber M3 parts, thanks.
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          Thats actually what I am thinking about switching to :)
          • King Luis
            • Sep 2004
            • 737
            i have the thr eyeballs arms and i thought they were going to be too harsh also. you do hear more road noise but the ride is nothing bad.
              • 34844
              that's only if yours don't pop.
              • Addissimo
                • Mar 2004
                • 1820
                I drove on my bushings like that for 4k miles before i got the replacement darin insert in there... Somehow they still fit. I hated myself for installing them backwards- I blame it on working on my car outside in 30 degree weather at that time.
                -Addis
                Doing something M50 related? -> http://www.addissimo.com
                On Myspace? ->http://groups.myspace.com/r3vlimited
                BF2142 SN = BillyGoose
                • nefarious7907
                  • Jan 2005
                  • 1170
                  werd
                  http://www.cardomain.com/ride/657387
                  • Digitalwave
                    is a poseur
                    • 6299
                    Your bushings shouldn't be failing like that... I'd be looking for a problem on a larger scale with your suspension.
                    RISING EDGE
                    • Addissimo
                      • Mar 2004
                      • 1820
                      dude... you have them turned inside out. get a new insert and re-install them the right way. there is a lip on the other side of the bushing that needs to be on the rear side of the car to hold that insert in. just email bmw bushings to get the phone number of the person who makes those inserts- they'll send you a pair for free.
                      -Addis
                      • Digitalwave
                        is a poseur
                        • 6299
                        -Addis
                        That's true... didn't notice that.
                        RISING EDGE
                        • Justin B
                          Sikky Nar Nar
                          • Mar 2005
                          • 4273
                          Umm, please explain where this 'lip' was, because one side is entirely flat (that you see) and the other, the urethane donut extends somewhat past the delrin insert but if memory serves me correctly does not overlap it. This hole in the urethane perfectly allows the end of the CA to sit in there, I think rubber bushings have something similar. Otherwise if that dip wasnt there for the end of the CA and was intended to be a bump stop to keep part of the bushing in, that shouldnt be coming out anyway, why wouldnt it have entirely covered it up on that side? Installing them 'your way' I would end up with a shallow hole in the urethane, perfectly sized to allow the bushing to further slide over the CA just a bit, facing backwards not doing a darn thing and probably not even overlapping the delrin anyway. If it did, just like what I said above why did it just so happen to not cover up that entire side of delrin, and have the perfect size hole to slide over the CA? The end nub of the CA that is extending out of the bushing I think is just about the same length that they extend out of rubber bushings too. Im pretty sure they did, its been a little while since I did it. I think I knew what backwards was, and the other side is installed identically. If you look closely the insert piece wasnt pushed out either, it seems to have been ground away. I just really dont believe that the lip of urethane I think you're talking about is intended to be a 'stop' at all. Im going to take my CAB's off soon and look at them more closely but its raining right now. As far as Im concerned right now about the argument in favor of the lip, is its a little far fetched. Why is my pass side cab still perfect? Not pressed out or ground at at all, and if that delrin needed a lip to stay on the metal where is the lip for the whole outer urethane piece? Thats right, its all molded together...
                          As far as my front suspension goes, here's everything I did in the front at the same time...they were new CAB's (obviously), new ball joints, new tierods, new shocks, new springs, new strut bearings, bigger swaybar set relatively soft for now and a strut bar but that shouldnt have anything to do with it in this case anyway.
                            • 34844
                            -Addis
                            get some glasses dude.. it's on correctly, here's my right side offset bushing:
                            • Justin B
                              Sikky Nar Nar
                              • Mar 2005
                              • 4273
                              Eh. I'll figure something out anyway.
                              Nando - I think what addissimo was saying is that the front side should have been facing backwards, and the rear side facing forwards, not that I have them in backwards as offset in the wrong direction. Then again I could be wrong. I do however still think I put them in correctly though as rambled about in my post above.
                              As far as calling to have the mfr resend one bushing, afaik RTRS no longer makes bushings. I bought them from Bav auto without realizing they were the same thing being sold by another site (below) and price matched it after I recieved them.
                              BAD NEWS
                              from R.T.R.S. As of 8-10-05.
                              -blah blah blah-
                              They do not have any plans to file bankruptcy, they have just decided to close the doors.
                              Parts production has already ceased.
                              http://www.suspension.com/bmw2.html something may have changed since then but I may just go with rubber bushings.
