Ireland Stainless Steel Brake lines make a huge differance in pedal feel!
  • parkerbink
    • Jun 2004
    • 10138
    I got a set of lines from Alex (thanks Alex) and put them in today. I have a 750 master, ATE powerslots, new pads front, disks, drums, pads shoes in back and it seems these made a bigger differance in the firmness of my pedal than all of the above.
    The feel was a bit soft and the pedal did go almost 1/4 in it's travel before now it is right at the top!
    Does this make sense?
  • nickmp0wer
    • 1427
    yeah mine seems real tight too. I have basiclly the same setup you do. although there is a little bit of play in the first part of the pedal travel. I saw some stuff under above the pedals that made it look like i could adjust it. Is it possible? what about the clutch?
    • MarkH
      • Jun 2005
      • 65
      I just replaced all of my brake lines with stainless steel, not IE, and there was a huge difference in the feel of the brakes. The pedal is much firmer and the brakes feel much more responsive.
      • Rob
        • 8166
        drums? I thought all later E30s had 4 wheel discs...
        post a review in the reviews section if you havent already
        BEERTECH
        • parkerbink
          • Jun 2004
          • 10138
          The rear disk contains a drum for the parking brake. Therefore it is a disk/drum which has pads/shoes.
          Per your request:
          • Brew
            • 3060
            A little bit of freeplay is absolutely critical for both the clutch and brake systems. Don't fuck with it.
            '91 318is
            • nickmp0wer
              • 1427
              well maybe since i installed a different brand master cylinder there is more free play than nessary?
              • Brew
                • 3060
                Its adjustable on the brake booster rod.
                '91 318is
                • ehlpitel
                  • Dec 2004
                  • 118
                  How tough is the install on the lines, I've heard some of the lines are easy to put in while the others are quite difficult, whawt exactly is involved in the difficult part?
                  • Digitalwave
                    is a poseur
                    • 6302
                    The hard part are the 2 lines that go from the body of the car to the trailing arms in the rear. Its hard to get wrenches on the lines.
                    RISING EDGE
                    • parkerbink
                      • Jun 2004
                      • 10138
                      Front EASY
                      Center NOT SO EASY
                      Rear EASY
                        • 34847
                        difficult, but not impossible. it's a whole lot easier if you drop the exhaust out of the way.
                        • Digitalwave
                          is a poseur
                          • 6302
                          I did it with the subframe off the car so it was easy.
                          RISING EDGE
                          • asubimmer
                            • 6482
                            how much are the ie ss brake lines? are the ones on ebay any good..haha prob not but its worth asking
                              • 34847
                              go look
