Wheel bearings?
    • 37833
    PelicanParta Sells FAG ones for $40
    So they're more expensive than BMA... As usual.
    Why do people like Pelican so much?
    Grover Beach, California
    BimmerHeads.com
    • e30 gangsta
      • 3877
      blunttech> all
      • cunninglinguist
        • Mar 2004
        • 281
        Originally posted by e30 gangsta
        blunttech> all
        $43.66
        • Herr Faust Schinken
          • Feb 2012
          • 3580
          shipping thats stupid fast , if order something at five pm on Tuesday it will be here at 9am Wednesday and there website is pretty easy to use
          88 325is Five Speed
          Lachssilber
          • ForcedFirebird
            • Feb 2007
            • 8300
            blunttech> all
            Originally posted by cunninglinguist
            $43.66
            Yeah but you can order one at a time with Blunt. BMA has minimum order requirements.
            john@m20guru.com
            Links:
            • S13_E30
              • 309
              Bought 2 from BMA last Thursday and they arrived yesterday. Quick shipping and I paid a little over $50 for both and free shipping!
              • S13_E30
                • 309
                I have come across an issue.... I was removing the wheel bearings with a rear wheel bearing removal kit and slide hammer....it was going great until only the inner part of the wheel bearing came out..the outer ring that holds the entire thing together decided it wanted to stay inside....is there any possible way to remove it without having to grind and cut it/ or replacing the trailing arms completely? wheels bearings just don't like me very much.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Shouldn't have needed a slide hammer if you have a wheel bearing kit. They always fall apart when using hard impact.
                  john@m20guru.com
                  Links:
                  • S13_E30
                    • 309
                    sorry I needed to be more descriptive.."kit" as in the kit used with slide hammer. The ones shown below.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Yeah I have never had much luck with the slide hammer and e30 wheel bearings.
                      If you need a cheap kit, do one of these...
                      http://www.harborfreight.com/fwd-fro...ers-66829.html
                      john@m20guru.com
                      Links:
                      • S13_E30
                        • 309
                        The slide hammer was a free rental tool. And ^that kit looks much better and I might actually have some harbor freight coupons laying around and I could possibly get it for cheaper. But I don't know if this will work now and get the outer ring out.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          It should. I have used that kit on an e30 before and one of the cups is the same size as the outer race on an e30 bearing.
                          john@m20guru.com
                          Links:
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            Oh, and your tool loaner should have a similar kit.
                            john@m20guru.com
                            Links:
                            • S13_E30
                              • 309
                              I'll have to go buy the set and try it out.
                              No, they didn't have it I double checked before I even looked at the slide hammer. But I might be better off buying the kit, maybe Ill do the front wheel bearings after I get the rears done.
                              • S13_E30
                                • 309
                                and thanks for all the help and info!
