Cost of powdercoating subframes and trailing arms??
  • e30serg
    • Dec 2006
    • 562
    Hey guys-I'm thinking about having my subframes and trailing arms powdercoated. Any idea on the cost?
  • ELVA164
    • 4861
    Easiest way would be calling up some local shops and getting a quote. I know some of the places around here will offer a discount if you can wait until a large batch goes through. That depends on the color and type of powdercoat you want, obviously.
    • Bearmw
      • 1323
      I would consider POR-15 or equivalent as another option as well.
      • bmwman91
        • Oct 2004
        • 3134
        They need to remove the old powder coating first, which is sort of a bitch. Most shops can burn it off of steel parts, but it gets them up to like 900 degrees which I would maybe worry about it annealing the steel. So, chances are that you'd ask them to blast it off. That adds labor.
        My guess would be $250, all said and done. I had an aluminum bike frame coated and they had to use aircraft stripper on the original paint. It cost me $125.
        Just remember that they still need to heat everything to ~450 degrees to bake the coating. You will need to remove/replace the wheel bearings and stuff. Do not have ANYTHING on there except the steel. Anything that can't take high heat won't do well.
        Transaction Feedback: LINK
        • Cletonius
          • 2809
          Whenever I've had stuff coated I've had to have it media blasted first. I don't think I'd want my suspension pieces heated to 900° and cooled arbitrarily. Uncontrolled heating/cooling changes the crystalline structure of the metal and could weaken it.
          My vote is for POR15 or standard chassis paint.
          - Josh
          1990 325is
          Need a shift boot?
          Looking to buy shift boot frames, PM if you have one to sell
          Here's what happens when you let the internet pick your license plate
