Subframe drop necessary for new bushings with 12mm riser?
  • blitzkrieg59
    • Oct 2004
    • 88
    This is maybe a stupid question, but I don't mind feeling a little stupid now and then.
    My rear subframe bushings are in need of replacement. I'm planning on renting an OEM tool to do the job so I don't have to drop the subframe. But I'd like to correct my rear camber with Revshift's 12mm riser kit. Is it possible to install that kit with the OEM tool/without dropping the subframe completely?
    "Have no small wrecks. If you are going to loop out and hit something, hit it hard." — H.S.T
  • arams325
    • 325
    yes it will work I have done it with the harbor freight make shift sub frame bushing tool, it took me under an hour per side
    • varg
      Florida Turbo Man
      • May 2014
      • 3429
      The riser bushings are 2-piece, so the subframe will have to come down to put them in.
      IG @turbovarg
      '91 318is, M20 turbo
      • HarryPotter
        • Jan 2010
        • 3642
        It won't have to be completely dropped out of the car. You can do it just by lowering it a tad.
        John F. Kennedy
