Bad Brake Master Cylinder?
  • CanadianDirty30
    • Sep 2015
    • 173
    Hey guys,
    I need some help asap to diagnose my problem this weekend. Today i was driving and my brake pedal has started going down to the floor when i brake. It still brakes slightly at the very bottom. I have read this is most likely a result of a bad master brake cylider. would this be correct? I do no have any leaks in brake lines, and there is no air in the system i dont think. Any info would help!
    91' 318is Brilliantrot
    Yes, it still has an m42
  • agent
    Vice Grand Pubaa
    • 7960
    Moved to the appropriate section. The FAQ/DIY section is for staff-approved instructional posts only.
    Originally posted by kronus
    • whodwho
      • Jun 2008
      • 1547
      A failing MC will typically start leaking or will the pedal will start sinking to the floor when light braking and still work ok when firmly braking and progressively get worse.
      If it is going straight to the floor it is probably air or not getting fluid. I recently pulled my MC and the grommet for the reservoir was breaking down and there were chucks of rubber that could easily blocked a port.
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • CanadianDirty30
        • Sep 2015
        • 173
        Well at first it was fine when braking hard and then when coming to a stop it would go down further slowly. It goes all the way to the floor now because it's gotten worse. But I'll check out all the grommets and see if any things breaking down. Not sure how air would have gotten in the system I haven't done anything with the brakes like flushing the fluid or anything like that ever.
        • jeffnhiscars
          • Jun 2011
          • 6011
          When you are stopped at a light if the pedal sinks slowly to the floor it's your master cylinder.
          Alice the Time Capsule
          • CanadianDirty30
            • Sep 2015
            • 173
            Yea that's what happens, started sinking when stopped. Now ithe MC is gone completely I think so it just always goes to the floor now
            • stonea
              • 2892
              Get a 25mm master cylinder when you replace it
              My Garage
              Feedback
              Instagram: Stone.Hopkins
              • e30_world
                • Aug 2014
                • 586
                Your master cylinder could just need new grommet seals underneath reservoir. Just did this to one of my e30's and problem was solved. Another way is to hook up the brake reservoir and do a pressure test. That's how I found my leaks.
                F80 M3 Alpine
                E10 Fjord Blue 2002
                E28 Blackish 535i
                E21 Silver 320i
                Disco1 98 4.6
                E30 Cirrus coupe S50 SOLD
                E30 325i SOLD
                E30 Alpine 325i vert Euro spec SOLD
                E30 Alpine coupe 325is SOLD
                • CanadianDirty30
                  • Sep 2015
                  • 173
                  I found a master cylinder and brake booster for not to expensive, so I picked those up and the problem should be solved once I install
