Toe Out in the rear. Subframe or Trailing Arm?
  • BaltimoreBimmer
    • Apr 2016
    • 307
    Replaced all the bushings in the rear end of the car. Did not change the suspension (appears to be billies and oem springs). Got my car alligned and it's giving me a negative toe reading in the back right side. It's out of spec by about 0.45 degrees. Which part is messed up? My subframe or the trailing arm? Is this terminal?
    It could be bad trailing arm bushings, bent trailing ams, or rarely a bent subframe.
    I'd start with the bushings and go from there.
    • BaltimoreBimmer
      • Apr 2016
      • 307
      I just replaced all the bushings though :/ like 500 miles ago
      • varg
        Florida Turbo Man
        • May 2014
        • 3424
        Is your ride height even? With our semi-trailing arm suspension, toe changes with ride height, if one side is too high it could cause toe to be out of spec, though camber would also be affected. It's certainly more likely to be a bent trailing arm than a bent subframe.
        IG @turbovarg
        '91 318is, M20 turbo
        • BaltimoreBimmer
          • Apr 2016
          • 307
          I'll look into it. Thanks for the tips!
