Rear subframe bushings
  • ElJimo
    • Jun 2012
    • 166
    I know this is the wrong subforum, but nobody ever goes in the rear suspension/arms. So, i apoligize.
    I was trying to press in my rear wheel bearings by myself, but I fear that i'm fighting a losing battle here. any pointers/suggestions?
  • MR E30 325is
    • Dec 2008
    • 3300
    Did you thoroughly clean the inside, where the bearing goes, after you painted the trailing arm?
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • wworm
      • Dec 2016
      • 1719
      lil bitta grease, make sure everything's clean, get some big ole wrenches and make sure you ate breakfast that day
      1984 Delphin 318i 2 door
      • ElJimo
        • Jun 2012
        • 166
        Inside was cleaned and lightly lubed.
        Just keep cranking away? I'm worried about getting it jammed on an angle or something.
        • TobyB
          • 5228
          Well, your first problem is that they are orange....
          ...but seriously, light taps on the outer face of the outer race can aid a ton in alignment.
          It doesn't take much, if you do it just right, and then all of a sudden when
          they're aligned exactly right they pull in pretty easily.
          But yes, it takes a lot of force. Lube the threads on your puller.
          t
          • slothonaleash
            • Sep 2014
            • 88
            Put the bearing in your freezer over night. Also, these are much easier to do with the arm installed on the car.
            • jeffnhiscars
              • Jun 2011
              • 6010
              Originally posted by slothonaleash
              put the bearing in your freezer over night. Also, these are much easier to do with the arm installed on the car.
              ding ding ding !!
              Alice the Time Capsule
              • Massive Lee
                • Sep 2006
                • 6785
                I too would put the bearings to freeze. And I would allow the trailing arm to sit under the sun to get a bit of heat. And make sure the bearing is 100% aligned. ;-)
                massivebrakes.com
