more subframe headachs
  • scobaru
    • Nov 2007
    • 396
    so I was able to drop my subframe but the top part of the bushing broke in the car.
    I tried this method
    but as hard as I hit it won't come out and it will just get to the point where a hard enough blow will just push the bolt right out.
    I've tried to drill it out by my drill bit is only so big and it really didn't make a difference..
    how are you guys drilling it out and how bit of a bit are you guys using?
  • FredK
    • 14763
    I had this happen to me twice. I used a 1/8" drill bit to make small holes in the bushing, drilling in a line, then I used a cold chisel to crack the rest of the bushing out. Get plenty of drill bits.
    • moatilliatta
      • 6158
      i used the bolt method. Find one that will thread further up in their and hammer from the top...
      @Zakspeed_US
      • Teaguer
        • Sep 2004
        • 6167
        Blast it with a fire extinguisher to freeze it then chisel it .
          Or you could invest in a bushing tool set...
          • DCColegrove
            • 2748
            Big Ass Bar and a Big Ass hammer.
            Oh and you have to pull the SF all the way out.
            • SamE30e
              • Sep 2007
              • 4319
              Blow torch.
              1985 325e 2.8 Turbo VEMS
              • scobaru
                • Nov 2007
                • 396
                whats the SF?
                the bolt I have will thread all the way up but it still does it. I most likely will have to chisel it. I might try to freeze it with that spray freeze stuff
                • scobaru
                  • Nov 2007
                  • 396
                  the bushing tool set would be useless on the part thats broken in the car.
                  I have a press that I use to press in and out my bushings on the part it self like the subframe but it won't do me any good because of whats broken in the car
                  • e30_kid89
                    • Apr 2006
                    • 489
                    I used the FredK technique and the metal sleeves bushings popped out with a couple forceful blows no problem. The trick I find is to use some heat on the bushing while you pound furiously at it. If you have the rest of the bushing out and a chisel gun i would get a long tip and chisel away at the remains.
