Bolt removal on control arm question....
  • Schneider325
    • May 2004
    • 3818
    #31
    What worked for me:
    22mm crows foot and Extensions on the drivers side to break loose, then just a regular 22mm wrench from underneath. On the passenger side you need a swivel/U-joint along with the 22mm crows foot and extensions to clear the exhaust. After that a 22mm wrench from underneath got it off just fine.
    • turboeta
      • Aug 2007
      • 571
      #32
      I used a open end 22mm then a stubby 22mm. It was a real PITA...but not as bad as getting the ball joints out.
      635csi Euro/Alpina B7S
      • 92 mtechnic cabrio
        • 4907
        #33
        you guys think that's bad?
        try threading the pipe between the clutch slave and clutch master...
        R.I.P 07/01/09 - 04/23/10 :(
        • Schneider325
          • May 2004
          • 3818
          #34
          ^that took some time
          • clydesdale
            • 631
            #35
            I just had to tackle this myself. I just don't get why everyone is saying a 22mm wrench. My car requires a 21mm and the replacement control arm nuts use 21mm as well. I too did not have a 21mm crows foot and could not get enough leverage onto my 21 mm wrench. So I used my 22mm (which was clearly too big) o2 sensor removal tool from bavarian auto. It is essentially a crows foot. So, I am not sure why everyone keeps saying a 22 mm when on my 87 it is clearly a 21mm nut. But either way, the crows foot concept worked perfectly on the passenger side. If that failed, I was going to bend a wrench.
            • MIKe30
              • Sep 2006
              • 2334
              #36
              just took mine off with a 22, worked fine. (91 318is)
              after you get the nut off, is there something else holding the stud in? CA doesnt want to come out still.... :?
                #37
                The ball joint stud is probably corrosion seized into the sub frame. Liberal application of PBlaster or Kroil and time for them to work (hours to days) followed by a heavy impact will usually release the stud. In extreme cases it may be necessary to drop the subframe and press out the stud.
                • Red88
                  • Nov 2008
                  • 1161
                  #38
                  FUCK THAT. That took me waaaayy too long.
                  Have you made a purchase from www.blunttech.com recently?
                  sigpic<< wrecked
                  • StereoInstaller1
                    GAS
                    • 22679
                    #39
                    I want an angled 22mm gearwrench
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • e30s52
                      • Oct 2007
                      • 5235
                      #40
                      They are great! I have a snap-on one and not a day goes by that I dont use one of them. Best tool I have bought so far.
                      www.gutenparts.com
                      • zedfez
                        • Jun 2008
                        • 67
                        #41
                        I just pulled the passenger control arm on my iX and it was a bit of a pain, but with a 22mm combination wrench, it only took me 3hrs total to pull and replace it. I had a shop pop in my new inner ball joint for $10, and was good to go. It was one of the easiest things I have ever done on that car.
                        The only trouble I had was keeping the inner stud from spinning. Putting a jack under it didn't work, but the top of the stud was flat on two sides and unthreaded, so I just threw on a pair of vice grips to hold it still.
                        Maybe it was just karma from the week long leaky gas tank hell project in which every single bolt snapped when I tried to remove it.
                        • 3bvert
                          • 1032
                          #42
                          did not have a Metric crows foot, broke em loose wiht metric wrench, then used a sae crows foot and sae gear wrench, near enough same size
                          even had an old wintworth ( old british) stubby that fit in too
