wilwood + corrado rotor idea
  • p0cket penguins
    • Jul 2008
    • 481
    #31
    Originally posted by Money$hift
    I like your ingenuity, but I think that entire spacer/braket setup looks questionable.
    i didnt use a rotor spacer... the bracket is made of 304 ss ... the two piece rotor is machined with the correct offset.... also the disk infront is an adapter for a porsche rim.. which will not be used on teh track
    • cheades
      • 632
      #32
      Just a note, but Stainless material is not the strongest material and is generally softer than carbon steel.
      • p0cket penguins
        • Jul 2008
        • 481
        #33
        well i dont think its going anywhere considering the bracket is made of 304 ss thats .64 in thick and .375 in at the offset, plus the threads are roll tapped. ill be testing it and replying back in teh furture.
        • 2002maniac
          • 4260
          #34
          Should be plenty strong. What are the specs on the rotor/hat?
          • p0cket penguins
            • Jul 2008
            • 481
            #35
            7075 t6 aluminum roll tapped .... similar design that wilwood uses..
            UPDATE... i just tested the brakes out today and there was a considerable difference....yet i feel i might have to re bleed the brakes....
            • 2002maniac
              • 4260
              #36
              What size rotor? Part number? What offset on the hats? They turned out great btw!
              • p0cket penguins
                • Jul 2008
                • 481
                #37
                The rotors size and part number
                Diameter 298.5mm
                Bolt ring 8 x 177.8mm
                rotor thickness 20.6mm
                part number 160-0471 from wilwood about 30 bucks each
                8.1 lb
                the offset of hat is 7mm added to the 20.6mm from the rotor and its a total offset of 27.6 mm
                I tested a couple hard stops and the brake balance seems to be fine..... yet i have to still throw on new rotors and hawk hp plus pads with ss lines .......PLUS i put a ton of that brake goop on the back of the pad and so far no squeeling pads
                • rbn14
                  • Sep 2007
                  • 18
                  #38
                  Your confusing mechanical properties. 304 stainless is much harder than A36 steel, a rockwell hardness of 92 vs. 20. As far as tensile strength the yield strength of 304 vs. A36 is about 30 ksi vs. 36 ksi and ultimate is 75 ksi vs 58 ksi.
                  Penguins - it looks like things turned out great! Where did yo source the hat? What are your plans for the rear.
                  • p0cket penguins
                    • Jul 2008
                    • 481
                    #39
                    fastbrakes.com sourced the hats... so far im running blanks with hp plus and ss lines... the stopping power is muuuch muuuuuuuuch greater than before as is.... i think the next thing is to upgrade the mc to a 25mm
                    • rbn14
                      • Sep 2007
                      • 18
                      #40
                      Are you thinking about upgrading the MC due to pedal travel or feel?
                      • p0cket penguins
                        • Jul 2008
                        • 481
                        #41
                        just want a tighter pedal feel... i think ill decide after i rebleed the brakes.
                        • ian e30 318is
                          • Mar 2007
                          • 1809
                          #42
                          +1. straight out of the material strengths book. ;)
                          1991 LS1 Swapped 318is
                          Instagram:
                          https://instagram.com/saltybeast/
                          LS Build Thread:
                          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
