Massive BBK Wheel Fitment Guide
  • meatball-e30
    • Aug 2020
    • 1
    #331
    Has anybody tried IE 4x100 Alpina replicas? He sells a 16×8 ET28 that is attractive to me.
    • hoveringuy
      • Dec 2005
      • 2693
      #332
      Dingg got the ball rolling by testing a set of 15x8 Sparco ff1 wheels over a Massive 300x22 Sport kit. I ordered a single wheel and was interested in seeing if it would fit over the 300x32 Race kit and how much spacing it would need.
      I found someone locally and tried it out.
      First, we tried the wheel with his existing 15mm spacer and it fit no problem. Clearance to the spokes was not even close to being an issue and about 3/16' at the closest point to the barrel.
      Went to a 10mm spacer. still fit great.
      Went to a 5mm spacer. Still fit great. Good clearance to the spokes and about 1/8" gap at the closest part of the barrel.
      Didn't try it without any spacer, but it would probably fit.
      Now, these wheels are 15x8 ET25 so it will take a 5mm spacer no matter what to make them clear the struts. I even run a 3mm spacer on my ET20 wheels for a little extra tire clearance.
      Final verdict, the Sparco 15x8 ET25 wheel available at the Tire Rack for $170 fits both the Massive Sport and Race kits without issue. A 5mm spacer (included by the Tire Rack!!) will be required no matter what brakes you run.
ID:	10025736 Click image for larger version
      • Massive Lee
        • Sep 2006
        • 6785
        #333
        Two thumbs up !!! Thanks for your research. ;-)
        massivebrakes.com
        • amcp
          • 489
          #334
          WELP I know what rims and brakes Ill be buying. Thanks for being the guinea pig hoveringuy
          • jjc034
            • May 2018
            • 107
            #335
            Hey everyone,
            I went to visit the Massive site and found out that the domain is no longer valid. Is Lee still doing brake kits for our cars? I'm having a panic attack right now as I would like to buy his kit specifically for my car.
            Let me know!
            Sent from my SM-G973U using Tapatalk
            • Netspeed
              • Feb 2022
              • 1
              #336
              Originally posted by jjc034
              Hey everyone,
              Let me know!
              I was in the same boat until I found out he's on Facebook and still posts his products there.
              • Northern
                • 5138
                #337
                I did the same recently. He said on FB that the site was hacked and deleted, should be back "soon".
                Unfortunately the templates don't seem to be available right now.
                Originally posted by priapism
                Originally posted by shameson
                • Saaboteur
                  • Jun 2022
                  • 1
                  #338
                  Has no one tried Enkei RPF1 in 15x7 or 15x8?
                  • amcp
                    • 489
                    #339
                    Order one and give it a shot.
                    • pilot20
                      • Jul 2014
                      • 21
                      #340
                      I am running Keskin KT4. 7.5 fronts. I wonder if they'll clear the 300mm set?
                      • Gokarter64
                        • Dec 2018
                        • 3
                        #341
                        Click image for larger version  Name:	dh2RKAp.jpg Views:	0 Size:	110.2 KB ID:	10070947
                        Click image for larger version  Name:	hn5eBMO.jpg Views:	0 Size:	88.9 KB ID:	10070946
                        15x8 et25 konig dekagrams fit and clear the 300x32 race kit perfectly with a 5mm spacer.
                        • Northern
                          • 5138
                          #342
                          This is great news! What size tires are you running?
                          • Gokarter64
                            • Dec 2018
                            • 3
                            #343
                            sorry for the late reply i don't get onto r3v much. im running 225/45/15 proxes r1rs
                            • R3VM3UP
                              • Jan 2017
                              • 170
                              #344
                              Reviving this old thread as it’s been a great resource. Has anyone tried the Team Dynamics Pro Race LT in 15x8 ET20?
                              Team Dynamics Pro Race LT 15x8 4x100 73.1 ET20 ET25 ET35 - several colors - flow formed - 10 spoke design - knurled bead area
                              Seems like it’s the perfect fitment for the E30. If it fits over the Massive 300x32 kit with superlite calipers it would really be ideal.
                              • Skafrog
                                • 1730
                                #345
                                I just bought a set and also confirm that these fit perfectly on the 300x32 kit front and rear. Running 225/45/15s with zero issues. I used to run 15x7 kosei K1's and had to shave the calipers down.
                                NASA MidSouth TT Director / GTS2 #018
                                Mods: Coastal PS Fluid, 10w40 Oil
                                Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
