control arm ball joints servicable?
  • shiboujin
    • Feb 2006
    • 2791
    Can I take my control arms to a shop and have them get me new ball joints and rubber boots or is it non serviceable? I want to not have to worry about these things anymore >_<
  • erik325i
    • Jan 2005
    • 3567
    The steel control arms are serviceable. The aluminum M3 control arms are not serviceable as far as I know.
    • shiboujin
      • Feb 2006
      • 2791
      steel == stock 325i right?
      • erik325i
        • Jan 2005
        • 3567
        yes
        • McGyver
          • 4619
          I got the E36 Meyle all metal ball joint control arms off BavAuto.com with the M3 bushings. They are 100 bucks for the control arm and 30ish for the bushings. They match up perfectly and i felt a HUGE difference over the stock ones. I went for the full control arms cuz the bavauto guy i talked to said that you cant replace the ball joint in the stock E30 arms, but you can on the E36 meyle ones.
          • JGood
            • Jan 2004
            • 7959
            Meyle is junk. Their control arms last me about 2 years.
            You can get replacement ball joints for the e30 control arms, but probably not from the dealer.
            You can get good Lemforder ball joints for about $30 each from partstrain.com, but if it were me I'd probably just get a whole new control arm. The labor to have them removed/reinstalled or the hassle of doing it yourself with a press sucks, and you still have used and possibly tweaked control arms. IMO, they are a wear item, especially at only ~$100 a piece with new ball joints already installed.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
