m3 Cab will NOT slide onto CA
  • 87e30
    • Jul 2008
    • 5676
    I lubed it, heated it, twisted it, pushed it and I can't get it to slide onto the cab to save my life. I called up a friend bigger than me, he couldn't get it on.
    Anyone successfully made a DIY rig? Or have a tip? I need to finish my car in a couple hours (well would really like to) And this is incredibly frustrating.
    I just hate everyone.
    No need for discretion.
    For this, you need a press.
    • BraveUlysses
      • Jun 2007
      • 3781
      you need a big fucking hammer, looooooob and the urge to smash
      I just did this the other day, really did need a 4lb "engineer" hammer to get it done. $15 at lowe's.
      • george graves
        • 19996
        watch your finger (they like to eat them)
        Originally posted by Matt-B
        • erik325i
          • Jan 2005
          • 3567
          Freeze the bushing/lolipop, then use lots of lube, and the heaviest hammer you have.
          Erik
          • flawdaboi407
            • Mar 2008
            • 324
            I used a long wood clamp. Put one end in one of the holes in the CA and the other on the bushing with a socket the same size on it and press it on. something like that lol
            84' 318i m30b35 swapped!
            • F34R
              sLaughter
              • 12376
              This is hows it's done if you don't have a bushing press. I love my press:p
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • ieatpeople
                • Mar 2008
                • 883
                i used a hammer and a chunk of 2x4 to install my offset delrin bushings. just sprayed wd-40 on the inside of the hole, then firmly hammered the bushings on with the block of wood in between to protect them.
                took about 5 minutes per side to install the bushings on the c.a. i had new control arms as well, so that made it easier i guess.....
                Originally posted by BillBrasky
                That's like Vlad challenging Chip Foose to a car painting contest.
                Originally posted by acolella76
                i'm pretty sure 'Phillis' is short for syphilis
                2007 CVPI, stock and slow
                1994 tercel, 5efhe swap, i/h/e
                1984 t-type, 5.3/th350 swap in progress
                My newest addition:
                Rebecca Arlene, born 4/19/2013
                • Lunner
                  • 222
                  +1
                  I made a tool out of some all thread, bits of sheet metal and some wood.
                  Look at BMW7246-2 on this page, http://www.technictool.com/bmw-thust-arm-tools.htm , you're basically trying to imitate that. Mine barely lasted long enough to do both sides, but it got them on.
                  87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
                  • 5KWattson
                    • Apr 2009
                    • 809
                    I lubes mine up with some soapy water, got a 2x4 block of wood with a lil help from a 64oz hammer they went on very snuggly
                    "God created turbo lag to give V8's a chance" Taylor D.
                    • 87e30
                      • Jul 2008
                      • 5676
                      thanks guys.
                      my new control arm just seemed too big. I ended up making a contraption at the hardware store then returning it. So I was only out 5 bucks and it saved a lot of time.
                      for you uys with hammers I tried, and I used a shit ton of laundry detergent as lube. So not sure you guys get them to slip on, or hammer on, but for future reference making a contraption is pretty easy.
                      • Wh33lhop
                        • 11705
                        BFH and a big socket. One side I didn't lube thoroughly enough so it got stuck when it was 80% on, that was fun trying to bolt the lollipop onto the frame, let me tell you.
                        paint sucks
                        • nrubenstein
                          • 3148
                          Dawn.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • Sagaris
                            • Sep 2009
                            • 2243
                            People who have used dawn/lube... I am about to install mine, should copious amounts of dawn be used? How much is too little? I just worry that going overboard will not allow it to dry and setup and too little will not get it on there (i know, i know, its a hard question to answer but do your best :P)
                            • FredK
                              • 14761
                              Just go overboard. The detergent will be squeezed out whether you put a lot or a small dab, as the fit between the rubber bushing and the control arm is very tight.
                              I use a weird looking contraption that I made from some all thread and a harmonic balancer puller. I bet one of those long wood clamps, as someone mentioned above, would work great.
