m3 Cab will NOT slide onto CA
  • 87e30
    • Jul 2008
    • 5676
    Originally posted by FredK
    Just go overboard. The detergent will be squeezed out whether you put a lot or a small dab, as the fit between the rubber bushing and the control arm is very tight.
    I use a weird looking contraption that I made from some all thread and a harmonic balancer puller. I bet one of those long wood clamps, as someone mentioned above, would work great.
    Yeah, I think that would have worked well.
    I used two of these:
    A bolt with fat washers to hold it together and through the control arm, then a flat metal bar across the top. Then bolted down.
    I just hate everyone.
    No need for discretion.
    • Lunner
      • 222
      I like that idea. I'll be stealing it for next time.
      87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
      • 87e30
        • Jul 2008
        • 5676
        It worked surprisingly well. I was upset I didn't try it earlier.
        • 2002maniac
          • 4260
          contraption is definitely the way to go.
          more KY helps.
          • Jesse30
            • Jan 2007
            • 3936
            i put mine on by hand with lube?
            i mean it wasnt easy, but didnt feel like anything to use a hammer for. pussies
            • 87e30
              • Jul 2008
              • 5676
              I'm thinking they are all just slightly differently sized, plus the variance in the control arm.
              There is no fucking way mine was sliding on.
              • BraveUlysses
                • Jun 2007
                • 3781
                were they standard e30 cabs? or offset, solid m3 cabs? the m3 cabs were extremely stiff and no amount of pushing would get them on.
                • scottinAZ
                  • Dec 2009
                  • 1312
                  so did I, but being as I was doing it laying down, it was a pain in the ass to get my weight behind it for a good push. Nutbusting pain in the ass, next time I make the damn contraption.....
                  I saved 15% on my Bimmer parts by switching to ...
                  • Jesse30
                    • Jan 2007
                    • 3936
                    offset solid m3 cabs ;)
                    • BraveUlysses
                      • Jun 2007
                      • 3781
                      is this you?
                      • bryant.cw
                        • 209
                        I used a two ton press that was bypassing hydraulic fluid (it was right at its 2 ton limit) in a floor mounted press to get my m3 offset solid CAB's on.
                        No way its going on with human power.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Are we talking about putting the bushing into the lollipop or putting the control arm into the bushing?
                          Bushing into the lollipop needs a press or careful hammering. Control arm into bushing requires some force too, but could be done by hand.
                          • 87e30
                            • Jul 2008
                            • 5676
                            It would have taken a very strong person.
                            I was sliding m3 solid offset bushing onto the CA. It was already in the lollipop.
                            Here is a diagram of the contraption I made:
                            Just play around with it until you find something that works. I got lucky and returned the eyelet bolts, in total a 6 dollar tool that saved me a lot of time. (after I'd already wasted a few hours)
                            • george graves
                              • 19997
                              Very nice man. Very nice.
                              Originally posted by Matt-B
                              • 87e30
                                • Jul 2008
                                • 5676
                                Thanks. Someone PM'd me asking how I did it, and I honestly don't have a lot of knowledge to share on here so it was nice to be able to help someone else out for once. (hopefully)
                                Thanks for all the help r3v.
