How low is too low in the front? (shock travel Q)
  • White325is
    • Oct 2006
    • 5947
    #46
    I used the stock gland nut with no problems.
    I think I cut my housings 1.5 inches and I used a 3 inch spacer.
    I will know for sure tomorrow when my new Konis arrive. I have to make up a new set of housings for my bags anyways..
    • red911turbo
      • Oct 2006
      • 222
      #47
      Yeah, let me know! I'm looking in to the same setup. Do you know if they bolt up to the normal koni GC camber plates? Also what did you use for your spacer?
      E30 325i 24v, E36 M3/4/5, MK2 GLI 16v, NA8 Miata
      Prestige Auto Repair
      Mercedes-Benz|BMW|MINI
      prestigegermanrepair.com
      • White325is
        • Oct 2006
        • 5947
        #48
        I used a piece of 1/4 inch thick pipe. Im also using them with the same ground control camber plates that I used on my bilie sports.
        • 91 318is
          • 1175
          #49
          Well I thought the rates were stamped on the springs but apparently not? And I can't find my receipt soooooooooooo
          Sold.......again.
          • White325is
            • Oct 2006
            • 5947
            #50
            Call ground control with the numbers on the springs. They will know.
            • 91 318is
              • 1175
              #51
              Good call.
              Sold.......again.
              • E30SPDFRK
                • 5693
                #52
                The rate is in the part number. They read (length).(diameter).(rate)
                ex. 0600.250.650 would be a 6" tall, 2.5" diameter 650lb spring.
                Byron
                Leichtbau
                • Stephen
                  Шлем ишака
                  • 10774
                  #53
                  ^ yes but those are only for more recent springs, some old ones arent set up that way
                  • E30SPDFRK
                    • 5693
                    #54
                    True, mine actually are the old way but I ass u me d that his were new
                    Byron
                    Leichtbau
                    • red911turbo
                      • Oct 2006
                      • 222
                      #55
                      since we are talking about shock travel...I think I have too much in the rear.
                      I'm running bilstein sports and they droop waaay too much. This allows the spring to fall off the perch when I lift the car. I have heard that the koni's that GC uses for the rear does not have this issue!?!? Does anyone have the koni part number of their GC kit?
                      Has anyone ever had Bilsteins shortened? My rear bilsteins also feel much softer in the rear than the front. Is this normal?
                      Cheers,
                      Chris
                      • 87e30
                        • Jul 2008
                        • 5676
                        #56
                        Whaaa? How did "ovaling out the hole" give you more strut travel? I'm missing something here.
                        I just hate everyone.
                        No need for discretion.
                        • 91 318is
                          • 1175
                          #57
                          lol
                          Sold.......again.
                          • ak-
                            • 12422
                            #58
                            Originally posted by 91 318is
                            Is that 450 in the front and 300 in the rear? That actually sounds about right.
                            I might be able to find the receipt with the spring rates, if not, I gotta jack up the car and look.
                            But that sounds pretty close. Is that considered soft?
                            Our cars are not miatas!
                            1991 325iS turbo
                            • 91 318is
                              • 1175
                              #59
                              I still haven't gotten around to call GC so see what the rates are. I may pass on the shortened struts as I don't need the front as low now. I would still like to put a little stiffer spring on there though.
                              Sold.......again.
                              • E30SPDFRK
                                • 5693
                                #60
                                Just get the numbers off your springs and enter them into the search bar on GC's site. No need to call.
                                Byron
                                Leichtbau
