The suspension setup/ride height thread
    quick cellphone pic
    Vogtland springs and e90 top hats
      I have a '90 325ic, is it going to sit lower being a vert on any spring I choose?
        amazing IMO, makes me want these wheels. mine is Dschwartz and i think gold would look pretty good..
        Originally posted by simplyclean325i View Post
        recently got euro smileys, took the rack off. is lip is going to be painted black and euro trim is going to be ordered soon. new tires, 215/40/16. need new wheels sometime soon, not sure what i want though.
        here's a recent picture.
        Uploaded with ImageShack.us
        on bc coils. dropped all the way on the back. getting shorter/stiff springs for the rear and going to drop it more.
        My old Style 5 Thread / My Swap
        1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
        IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
        1998 528I (Sold) // 2003 540I ///M Sport
          I can't decide between b&g springs or Ireland Engineering 3 springs. Which are softer which are stiffer? Which ones seem to have a lower ride height? Any answers, suggestions would be appreciated!
          - happy motoring
          LEVINE AUTOMOTIVE
            - happy motoring
            get coil overs. ground control
              Originally posted by Wesley Vocino View Post
              Apex Springs- 2.4 inch drop
              Bilstein Sport Shocks
              so fucking sick.
              Originally posted by ApexGoblin
              well make sure your priorities are straight... e30 first :up:
                Bilstein Sports (Bumpstops cut in half)
                GC 500fr / 750r
                M3 Offset Bushings
                IE RSMs
                Stock Strut Bearings for now
                  Bilstein M3 sport shocks
                  Eibach race springs.
                  1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                    Kw v1 with bottom rear spring pads in and about 1/4 thread left all the way around
                    My Pleasure:02 Honda 954, 02 Fronty 4x4
                    My Pain:91 BMW E30, 90 S13(sr'd)
                    "granthr said: ↑
                    I mention Metric Mechanic because it is a great way to empty your wallet to get unverified horsepower gains."
                      H&R race kit
                      Alpina Kopis 17’s
                      I love the way it drives, a little body roll but perfect for a daily. A good set of sways and you are good to go.
                      Follow my IG @bouchezphotography
                        Turner J-stock suspension on 225/45/16's
                        Due to the crappy roads up north, I'm moving on to some Megan coils with more appropriate rates. I'll also be able to drop the front a little more 8)
                        ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
                        In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
                        I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
                          Here is my wheels I want to run on my sedan, I test fit them on my coupe. The coupe is on billy sports and eibach pro kit springs, idk if there are drop hats.
                          I'm looking to get the car down to the rubber prettymuch.. is there another set of springs that could get me there (or if I run drophats?)
                            JOMs adjusted all the way down in front.
                            No adjusters in the rear.
                            No modification to from strut tube, still have spring perches in.
                            EDIT: Ill add a pic of the pan clearance. Benefit of having an m20. Decent amount of room for as low as it is.
                            I don't even own this car anymore, but I'm too lazy to change the picture.
                              my current setup
                              front:
                              gc sleeves
                              no name 6in 400lbs springs
                              cosmo adjustable plates
                              ge top hats
                              billy sports
                              m3 cabs
                              21mm vert bar
                              sparco replica strut bar
                              back:
                              eibach 6in 500lbs springs
                              no adjusters
                              ireland urethane subframe bushings and trailing arm bushings
                              billy hd's
                              ireland billet rear shock mounts
                              no rear bar
                              84 318i drift car
                              04 mk4 gti 1.8t
                              96 e320
                              63 plymouth valiant
                                Custom lowering springs with Stagg shocks all around. E90 spring hats with both pads in place for front and back.
