Supersport24 spring hats and Bilstein Sports>Crappy Pic
  • egk2
    • 2426
    Well when I first posted pics with the new Cr7's, a few of you had
    mentioned that the front could be a hair lower, I agreed, so I installed the
    Bekkers spring hats, also went with Bilstein sports, did not lower it as
    much as I would have liked but I think it made a bit of a difference :|
    Sorry for the second crappy pic, I didn't have my good digi.
    Before:
    After:
  • ///M Powered
    • Jan 2004
    • 1109
    Looks a lot better to me, good call.
    • royalflush313
      • Mar 2004
      • 2070
      how do you like the ride now? And how much of a drop did it give?
      I think your car looked fine before... but I guess it couldn't hurt for the front to come down a little more. Having said that, I can't really see much difference in the two pics because of the angles.
      ~ Go Canucks Go! ~
        • 34837
        I can't tell any difference. might just be the stretched tires.. nice car though!
        • egk2
          • 2426
          The bilsteins firmed up the ride a lot, perfect for a daily driver, the spring hats claimed to lower the front 10-20mm so...I can tell because it's my car but most can't tell the difference, hopefully the bilsteins will settle.
            • 34837
            that's probably it, the bilsteins are gas pressurized so they will raise your car a little bit. you still running spring pads?
            • egk2
              • 2426
              Yeah, I figured any drop the spring hats gave me was taken away by the
              Bilsteins, still running spring pads but they were flat as pancakes, wouldn't have made a difference, hopefully they will settle, if not I might have to look into coilovers.
                • 34837
                it looks fine, I wouldn't worry about it unless it really bothers you.
                • Brew
                  • 3060
                  You need some real tires to get rid of that fender gap. 225/45 would still give you the "stretched" look you desire, give you a better ride, better handling, and would fill up that gap.
                  '91 318is
                  • egk2
                    • 2426
                    I never said I desired any stretched look, the tires are basically
                    brand new and came with the used wheels. I do agree my next
                    set of tires will be a meatier tire, maybe 215/45/16's, with
                    225/45/16's I'd have rubbing issues in the rear, yes fenders are
                    rolled flat.
                    • Brew
                      • 3060
                      Oh, sorry. I must have mixed you up with someone else.
                      '91 318is
                      • egk2
                        • 2426
                        no problem
                        • Digitalwave
                          is a poseur
                          • 6282
                          Looks the same to me. I would never run deep spring hats again, too much bottoming out...
                          RISING EDGE
                          • egk2
                            • 2426
                            Yeah, I remember you mentioned that but it hasn't been an issue for me, had them on for a bit on all kinds of roads.
