easy way to switch springs
  • nickmp0wer
    • 1427
    I just got some m3 springs for $75 as a cheap upgrade until i get something else and i was wondering if there is a easy way to switch them. The rears seem like i jsut have to unbolt the shock then change the springs but the fronts seem like they will be a lot harder. can i just unbolt the 3 nuts on the strut tower then lower it down, use the spring compressor and undo whatever holds the spring on? im going to be doign the brakes and wheel bearings at the same time if that matters
  • kencopperwheat
    King of Kegstands
    • 14396
    You need to pull the whole strut housing out of the front
    Originally posted by Gruelius
    • nickmp0wer
      • 1427
      damnit
      • Dave
        E30 RAT
        • 11675
        do you remove the strut nut on top before or after you remove the strut housing?
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • kencopperwheat
          King of Kegstands
          • 14396
          You need to remove the whole houseing before that.
          • nickmp0wer
            • 1427
            • Dave
              E30 RAT
              • 11675
              Originally posted by nickmp0wer
              http://zoso.no-ip.org/318i-frontsuspension.html
              That is what I was thinking - like this guy says, break that top nut loose before you remove the housing, but don't remove it.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • parkerbink
                • Jun 2004
                • 10138
                Great writeup. Could of used it 6 months ago when I did this.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  I don't understand why he says to do that. It's just as easy to zip it off with an impact gun with the whole assembly out of the car.
                  He should have mentioned to make sure and replace the grease retaining washer under the strut-mount and the spacer washer between the mount and the spring hat. There are a number of people on here who have forgotten them when doing this job.
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    If you dont have an impact gun... break it loose before you get the strut out of the car. Otherwise that son of a bitch will just sit and spin :)
                    Will
                    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                    Welcome e30 (brilliantrot '90 325is) 12/23/06
                    DaveCN = Old Man
                    My signature picture was taken by ME! Not by anyone else!
                    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Will
                      I've had experience with them still spinning while in the car...
                      • ///M Powered
                        • Jan 2004
                        • 1109
                        ^^ Same.
                        • Mystikal
                          Wheel Fitment Expert
                          • 9602
                          Me three.
                          Had to jam multiple vises on the shaft (was tossing the old Konis, of course the shaft was toast afterwards) and it was still an hour long affair.
                          • Nick325is
                            • 1409
                            It is possible to change the strut and springs without removing the strut housing. I did it a couple years ago when I changed my suspension the first time. All I did was remove the sway bar link and the upper strut bearing and compress the spring then pull it out followed by the strut.
                            Nick
                            • Digitalwave
                              is a poseur
                              • 6293
                              Nick
                              It's so much easier to do it off the car, and it only takes removing 2 more nuts to get the whole strut out.
                              RISING EDGE
