Camaro Shocks
  • IronFreak
    • Dec 2012
    • 3702
    #241
    That might be the case, but if in-fact your shock is supporting weight like that, expect it to go out faster....your springs aren't doing there job if they sag that much.
    Instagram @rebellionforge
    • ToPLeSS(e30)FeinD
      • Jul 2011
      • 2813
      #242
      If any of you have owned a Ford Explorer, u can second this. The difference in height on a car between brand new shocks and blown out shocks is small but noticeable. Both of you are right, on cars too light to provide sufficient weight to prove this theory, the difference is finite. But it does exist.
      Side Note: Wasn't this thread regarding Camaro shocks and similar applications? Let's try to keep it on topic. And PLEASE read before asking questions. The redundancy in this thread is getting out of hand.
      '89 Delphin 2.8 Cabrio
      '94 Yamaha FZR 600
      Originally posted by FlexdXJ
      Is that thing on air?
      • Mr. Tasty
        • Jul 2011
        • 3421
        #243
        this is leading to the same idea that indeed pistons have 0 velocity at TDC and BDC and stop. I am just saying that the height is not initially governed by shock compression.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • bnyhan
          • Apr 2013
          • 45
          #244
          I have read through this entire thread, considering the front mr2 shocks and cutting the housings down 2 inches and running them with my ground control coilover conversion kit. Has anyone used this setup with camber plates...? Would you run MR2 camber plates? or...
          • einstein57
            • Jun 2007
            • 10780
            #245
            Chris had the struts turned down 1mm
            www.gecoils.com
            • KW E30
              • Jul 2012
              • 71
              #246
              is the mr2 rear struts fit e30 front struts without modification? how about the camaro shock they fit without modification? thanks
              • Rockwool2117
                • Jan 2013
                • 143
                #247
                far as camro shocks go would gas adjusts be somewhat compatable with eibach pros. or should i just buy bilsteins sports
                The day I bought my e30, was the day I became sophisticated and classy as fuck.
                • XvillainousX
                  • 176
                  #248
                  Its been a while since I surfed this forum. If camaro struts are truly an option, might I suggest a premium option for those of you who are track oriented.. QA1. They make single and double adjustable struts and 276 different valve options.
                  Texas Speed & Performance is your one-stop shop for all LS and Gen 5 LT1 & LT4 performance parts and engines! We are among the largest LS and Gen 5 LT1/LT4-specific shops in the country, and we machine and assemble all of our engines, camshafts, and Precision Race Components cylinder heads in house! We also have a complete line of Texas Speed & Performance crankshafts, connecting rods, rocker arms, long tube headers, exhaust systems, and more. Come by for a facility tour, or check out our facility tour online!
                  • osborne519
                    • Jun 2013
                    • 17
                    #249
                    a pair i found on ebay im not sure yet if im going to do this set up yet or not.. but i put in the rear part number and these poped up on ebay... double check me but its 75 for a used pair
                    • RGCintha29073
                      • Dec 2009
                      • 471
                      #250
                      Originally posted by osborne519
                      http://www.ebay.com/itm/93-02-KYB-AG...badac1&vxp=mtr
                      I bought those! Got um for $65 + shipping. I'm installing them today.
                      • einstein57
                        • Jun 2007
                        • 10780
                        #251
                        Amazon has a warehouse deal on the adjustable MR2 rear. There is only 1 left at $44. There were three but somepone just bought two for no reason.
                        www.gecoils.com
                        • penpen
                          • Mar 2008
                          • 69
                          #252
                          so this sleeve to make the rear bushings on the camaro shocks fit snug on the m12 bolt, any info on what to look for at home depot/lowes?
                          • dsm2002
                            • 193
                            #253
                            you can get a 1/2 inch to 12mm step down spacer (part no BD4-Z005A02) from eshocks for for about $4ea
                            • Mr. Tasty
                              • Jul 2011
                              • 3421
                              #254
                              so just to clarify, which I think should be done on the first page.
                              for the e30 front you can use:
                              aw11 front or rear shocks?
                              for the e30 rear you can use:
                              87 or w.e-2002 camaro rears?
                              (Daily Driver)
                              KW V2 Coilovers
                              • CubbyChowder
                                • Mar 2012
                                • 1488
                                #255
                                I have a quick question regarding the KYB AGX Camaro rear shocks. I'm seeing compressed heights for Bilstein's in this thread but have not found the compressed/extended heights for the KYB AGX's (not sure if they would match the Bilsteins or not). I ask because I'm considering fitting some on my bagged BMW 2002 and need specific compressed/extended heights for the rear shocks. If someone could post those specs it would be appreciated!
                                --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
                                --Golden Boy E30 Build Thread-- (sold)
