Camaro Shocks
-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good looking -
Go to your local kyb dealer and buy one. Its more then just the length of the assembly. Valving, eyehole width and diameter, shaft length and diameter. Take measurements, post your findings, and get a refund.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
I received the inserts (brass bearings) part # 6659k15 from mcmaster.com for the rears and popped them in. The are not as long as i'd like but they work ok when you torque them down. The quality of the bearing is crap. It is a cast piece with a fairly rough surface. I installed the shocks with some brand new IE RSMs using the supplied hardware that came with the KYBs. The fronts mounts need to be 1mm larger then stock.
www.gecoils.com
No they would not, the MR2 insert requires that you swap the strut mount bearing as there is a 1-2mm difference in shaft size (vs e30 stock)______________________________________
1984 LSB 318i - Sold
1986 325i - Motor Swapped Track Car Project
1995 318ti - Sold
1999 540iA - Daily DriverComment
Somebody reported that the non adjustable kybs were stiffer then bilstein sports on their build thread.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
I've also been running the cheaper KYB Gas-a-Just rear monotube shocks for couple of months now with no issues. I have a set of Bilstein Sport rear which I was going to put on but decided to try the KYBs after messing up one of the top threads on the Bilstein. Can't really make any direct comparison claims as I've never run Bilsteins before but these KYBs seem to ride pretty good and stiff. Can't beat the price! :)Comment
Any update on how they are and a write up? :)Comment
Then in addition to that you would need to slightly modify the lower eye of the Camaro shocks by pressing in a slightly different bushing.
Then on the front MR2 strut inserts you would need to modify your camber plates if you have them for the slightly larger MR2 shafts, and also come up with a spacer to fit inside the strut housing because the MR2 strut insert is shorter than the OEM or replacement inserts.
Does that about summarize it or am I leaving something out?Comment
