new control arms and m3 offset bushings
  • A_325i
    • Jun 2005
    • 680
    how hard are they to replace? seems pretty straight forward...but what about the bushings will i need a machine shop to get htem out and press ther new ones in? i hope not cause god damnit i cant afford that right now
    is there any special way i could do it at home i got plenty of tools at my disposal
  • Schneider325
    • May 2004
    • 3818
    Re: new control arms and m3 offset bushings
    Totally replacing everything is the easiest!! To take off the outer most ball-joint just hit the shit out of the top with a BFH and it should drop. Doing the middle ball-joint is going to be the hardest. Make sure you spray a lot of penetrating oil up in there, good luck with that. Then just take out the two bolts for the CAB and it should come right out.
    If you cant pull the bushing right off then just take a hacksaw or torch to it. I prefer fire :)
    If your going with rubber bushings then you can take it to a press shop and have it done for about $20, so it really isn't that much!!
    Good luck
    • A_325i
      • Jun 2005
      • 680
      well i have balljoint seperators so the inner and outer balljoints shouldnt be much of a problem i also have lots of big hammersi was just wondering about the bushing (i bought the solid rubber m3 offset bushing) i was told i'd have to get it pulled out and then pressed in by a machine shop....btw do i have to replace the bracket while replacing the bushing or can i reuse that if so where do i buy one? i've looked everywhere and cant find one
      • Schneider325
        • May 2004
        • 3818
        You can re-use your old bracket. you dont need your old bushings pull out by a shop, you can just cut/pull/melt them off.
        you can get creative and push the new ones in yourself. I've seen two articles, only could find one
        someone else could chim in with other ways
        • A_325i
          • Jun 2005
          • 680
          alright so looks like i will end up having to go to a machine shop...alright thats cool at least its cheap..
          • Schneider325
            • May 2004
            • 3818
            There is another method that involves using a block of wood and hammering it in, if you want to do that
            • kencopperwheat
              King of Kegstands
              • 14396
              You'll most likely have to take it to a machine shop. I wasn't able to get close to pressing my new ones in with a vice.
              Originally posted by Gruelius
              • A_325i
                • Jun 2005
                • 680
                lol i just found out that my control arms that are ont he car now have m3 offset CAB's lol i never knew that...could that be a contributor to the harshness going over bumps and train tracks? or was that just from my crappy stock suspension it only really happened to the front of the car...
                • Digitalwave
                  is a poseur
                  • 6299
                  The offset of the CABs don't have to do with harshness, its the material used. It'll be harsher if you buy urethane CABs, which you should if you are replacing them. You will have to have them pressed in by a shop.
                  RISING EDGE
                  • A_325i
                    • Jun 2005
                    • 680
                    well i already purchased the solid m3 offset cab's so eh
                    • uflnuceng
                      • Apr 2005
                      • 1049
                      Same here... unless you have a hydraulic press lying around you need to take it to a machine shop. A local guy did it during his lunch break for me and charged me $10.
                        • 34844
                        that method will never work. it takes something like 15 tons of pressure to get them in. freezing the bushings and heating up the brackets doesn't work either. the brackets are actually not completely round, which is part of the reason they are such a bitch to press on. it's much easier to pay $20 and let the guy at the shop waste 15 minutes of his time instead of wasting a day of your time only to end up bringing it to a shop anyway..
                        • A_325i
                          • Jun 2005
                          • 680
                          ok so a vice doesnt work? alright ill just bring it to a shop...btw is it just as hard to put the new bushing and bracket BACK onto the control arm? do i need a machine shop to do that to or can i do that my self with some dish soap and alot of force?
                          • Digitalwave
                            is a poseur
                            • 6299
                            Fast learner...
                            RISING EDGE
                            • uflnuceng
                              • Apr 2005
                              • 1049
                              need a machines shop for both removal and installation... seriously... $20 for both together is all you'll end up paying.
