symptoms of bad steering rack?
  • benz-tech
    • Jan 2011
    • 368
    This has turned into somewhat of a thread jack but....FWIW, with the alignment heads on and the toe-in set at 0, I will raise and lower the car, (up with the jack, down with a few large co-workers hanging on it) and measure the change in toe in at each postion. I will then compare the 3 possible shim combinations to see which one minimizes the toe change through the suspension sweep. I am also curious to try this with the steering wheel turned 180deg. I searched a few threads and everyone seems to lean toward shims on the bottom now but from what I have found no one has posted any hard data. I'll start a new thread with the results.
    You say "Where are your other two cylinders?"
    I say "Where's your other camshaft?"
    Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
    • matt0300
      • 549
      I figured out what it is Derp. Bad wheel bearing Lol I can't believe I didn't realize it sooner thanks for all the info guys.
