sparco strut bar trouble
  • 318driver
    • 1714
    Ok, so im attempted to put my strut bar on my 85 318i and im having some trouble. Its about an 1nch off. so i jacked the car up. Is an 1in way too much, or do you think it will settle by tommorow so that i can put the bar on?
    90 325is
    IE stage 3s and refeshed m20....
  • bimmer8604
    • 3017
    i take it your struts are an inch too narrow.
    Wasnt there something going around saying that there was a difference in some of teh strut towers, like some were narrower than others?
    back to your car, you should beable to just jack it, and just make it fit. When i did mine on my old car i had to kinda push down on the tires a bit.
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
      • 34839
      1 inch seems to be a little extreme for chassis sag.. I think you would know if it were that bad (there's not much gap between the stock hood and fenders). I don't believe at all that your chassis is sagging that much. kinda like my strut brace (almost 1" off), there was no way it was the car's fault, I could see maybe 1/2".
      • AdamF 88iS
        • 2051
        An inch is a lot. Has the car been in an accident in the front?
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Jordan
          • 12913
          cut the ends off and weld them back to the bar on the car.
          https://mtechniqueabs.com/
          • egk2
            • 2426
            Andrew, check your pm's.
            • 318driver
              • 1714
              I dont beleive the car was in any accidents.
              ed, if i cant get it on tommorow then maybe ill give that i try.
              Ive also thought about going with IEs smaller bar and selling this one.
              90 325is
              • Jordan
                • 12913
                Psst. My car has never been in any serious accident aside from sheet metal (fender/hood) dents.
                My Sparco bar was also about an inch too long. I cut the ends off, shortened the bar, and welded it all back together.
                Then I bead blasted it, and had it painted body color.
                Just do it, or pay someone else to. Won't be that bad..
                • arsevader
                  • May 2005
                  • 1025
                  There is a lot of talk about there being two different measurements for E30 strut towers it's undocumented but alot of people are having the same issues.
                  James
                  • 318driver
                    • 1714
                    well i dont really feel like paying someone else to modify this strut bar, so i guess ill just sell it and buy the IE bar.
                    Anybody wnat it? it will go up in hte FS section soon
                    90 325is
                    • egk2
                      • 2426
                      Andrew, how do you know the IE shorter version will fit?
                      I bet you'll end up modifying that one.
                      • King Luis
                        • Sep 2004
                        • 737
                        wouldn't cutting the strut tower bar make it lose some of it's strength???
                        • DarkWing6
                          • Apr 2004
                          • 7144
                          Not if you cut of the ends and not in the middle. They don't make them from one piece of metal.
                          • King Luis
                            • Sep 2004
                            • 737
                            i see cutting more of a hassle then selling this one or bringing it back and buying a new one.
                            • 318driver
                              • 1714
                              ed, they have actually messurements there. Ill also call them up and tell them that the sparco didnt fit, hopefully all will be good.
                              90 325is
