Easiest, best way to change power steering fluid
  • parkerbink
    • Jun 2004
    • 10138
    I was checking my fluids, basking in the psudo perfection that is my car now that all the work is done and it occured to me to see the color of the ps fluid which is not visible due to the fact that the little stick on the lid is black so I wiped it on a white paper towel and damn if it is not filthy.
    It is the only fluid I have not personally changed so I pulled out the ole Bentley and it gives the capacity, the way to replace the pump, the rack whatever else there is but all it says about the fluid it that it need be Dextron I or II (shit I have been putting ps fluid) and that there is no drain plug and that's it.
    So how do I r&r the freaking fluid?
    Thanks
  • AdamF 88iS
    • 2051
    Disconnect some hoses and let it drian until youre satisfied with how empty you've gotten it.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • parkerbink
      • Jun 2004
      • 10138
      Would that not leave the fluid that is in the pump and anywhere else that is before/after the hoses?
      Thanks
      • AdamF 88iS
        • 2051
        Thanks
        Yea, it would, but you'd empty out the bottle as soon as you disconnected the intake hose (easiest one to get); and the bottle is where the majority of the fluid is in the system. Best you can do aside from that is turn the steering lock to lock with something still disconnected (preferably the return line) to get as much out of the rack as possible.
        If it really bothers you, you can do a refill, run the car, then drain again to flush it out, but it's not really worth the time.
        Whatever you do, don't run the car with no fluid in there. Your pump will hate you for it.
        Adam Fogg- '88 M3
        • parkerbink
          • Jun 2004
          • 10138
          Cool, Thanks!
          • trashcop 80s 80s
            • Jun 2004
            • 1130
            I am planning on doing this during the christmas break. So is it ok to use ps fluid? I was going to use some Valvoline synthetic ps fluid, or should I take it back and use Dexron.
            • rs4pro3
              • 5808
              There is a large drain bolt on the Rack it self, not sure if it will get all the fluid out, But ussualy when I ship a rack, I undo that bolt and let it sit overnight to get the fluid out.
              85 325e 2.7 ITB'd stroker
              • parkerbink
                • Jun 2004
                • 10138
                I have been putting ps fluid in since I got the car over a year ago (I have not put in much as it does not leak) Bentley says Dextron I or II and I assume this is why my fluid is black and weird. I figure it must be right if it is in the Bentley.
                Thanks for the tip. I am on my way to the garage to do it.
                  • 34844
                  the system is designed for ATF. don't use anything else if you like your car.. and it's not like it's hard to find or anything.
                  • erik325i
                    • Jan 2005
                    • 3567
                    You are supposed to use ATF as stated in the Bentley.
                    I guess PS fluid will work temporarily (as you figured out), but it is best to switch to ATF next time.
                    -Erik
                    • trashcop 80s 80s
                      • Jun 2004
                      • 1130
                      The one that is a 22mm? I tried pulling that once, then there was another nut, I pulled that off and nothing came out. I think the only way to do it is to pull a hose.
                      Would it work if I pulled the return line and had someone turning the wheel while I add fluid in the tank to give it a flush? THe fluid looks pretty nasty and I want to try to get as much out as I can.
                      • Digitalwave
                        is a poseur
                        • 6299
                        -Erik
                        Yeah, it also says ATF ONLY right on the cap of the resevoir.
                        RISING EDGE
                        • bimmer8604
                          • 3017
                          Use ATF.
                          My shitty ass instructer at school told me i could use PS fluid, and after we did a flush(we have a nifty machine) about a week later it started leaking like a MOFO. So i had to flush it again with ATF. Still leaking, but not as bad as before.
                          Do some people not see that it says ATF ONLY on the cap? and just sit there and STILL put in the wrong stuff? I did it only because I believed my instructer, plus all the fluid was free. I dont think it hurt anything, but i'm doing a new rack soon(mines fubared)
                          Kyle
                          1988 M3, 97 840, 99 XJ
                          DILLIGAF
                          • parkerbink
                            • Jun 2004
                            • 10138
                            Mine does not say that, why is it a stretch to think POWER STEERING FLUID would go in the POWER STEERING SYSTEM? I have had no ill effects and I have now fully flushed my system & put in ATF.
                            • bimmer8604
                              • 3017
                              just check ur owners book, should say it in there.
                              Glad you got it changed...
                              Kyle
                              DILLIGAF
