Modify Z3 rack? change torsion bar
  • Dirtboy
    • 458
    Just installed the Z3 rack in my car. While I like the quickness of the rack compared to the original e30 rack, I'm not liking how it feels "over-boosted". I'm comparing it to my 2002 e46 and 2007 X3. The e30 just feels too light.
    Does anyone know if the torsion bar in the rack can be changed to a stiffer one?
    Nürburgring info
  • R3Z3N
    • Jan 2011
    • 3056
    ^^That I do not know, but I feel the same. Changing caster will also alter how much effort is needed off-center should you desire to play with the feeling that way. You might call rackdoctor.com (they rebuild racks) to see if they know.
    • Todd Black 88
      • Oct 2007
      • 3449
      Strange. I put a z3 rack in my e30 cab and I find it to be much less boosted than stock, and less than my e46 was or my new e93
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • bubbajan21
        • 1962
        Get a smaller steering wheel
        • R3Z3N
          • Jan 2011
          • 3056
          ^Smaller wheel still would not produce the desired effect.
            If the steering feels too light at speed and the alignment (front & back) is correct, adding front caster may help some. But the real cure would be to reduce the pressure provided by the power steering pump.
            • jeffnhiscars
              • Jun 2011
              • 6010
              I had an email exchange with Rich@rackdoctor.net and he said he could put e30 internals in the Z3 cores he has. I have no idea what he means but I'm guessing he is referring to the torsion bar or the valving. Since he is offering them outright with no core required you may want to get in touch with him as it sounds lie he will custom spec these.
              Alice the Time Capsule
              • Danny
                • 14216
                I've heard the e30 m3 high pressure line has a restrictor in it to make the steering a bit heavier. Maybe try that.
                • Dirtboy
                  • 458
                  Hmmmm.....
                  Nürburgring info
                  • R3Z3N
                    • Jan 2011
                    • 3056
                    Yes, the high pressure line I used from an E36 also has the smaller diameter hose in the middle on a clamp.
                    • nokincy
                      • Feb 2012
                      • 302
                      I know it's ricer, but try a power steering delete?
                      • Dirtboy
                        • 458
                        Car came with no power steering from the factory. Hated it. I like how quick the Z3 steering rack feels, just feels a bit over boosted. Guess I'm too used to the feel of my e46 steering.
                        Nürburgring info
                        • rturbo 930
                          • Dec 2005
                          • 2621
                          I might be making this up, but aren't e36 racks adjustable in that you can adjust the amount of power assist? Or did the Z3 racks come without that option?
                          • R3Z3N
                            • Jan 2011
                            • 3056
                            No, but that is the job of the torsion bar that dirboy and I are talking about, not a simple thing to change. You are thinking of the cap that some speculate as to its job.
                            • Hellabad
                              • 807
                              Those are actually not restrictors.
                              It is more like a little tiny muffler to keep the fluid from hissing like a Mustang.
                              The torsion bar flexes and "tells" the power steering when to start assisting, which is the only pure way to add feel to the power steering. (bypassing make the steering jumpy at slow speeds, but works on a race car)
                              Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                              Ground Control Gallery
                              The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
