German Engineering coilover help!
  • GUERONASTY
    • Aug 2011
    • 811
    So after I installed my GE coils yesterday my car's height in the front was nothing near like pictured below. At it's lowest setting the front it is sitting about 1-1.5" higher than the tire on a stock 14" basket weave 195/65/14. I installed with Billstein sports and IE street/track camber plates in this order...
    slid the coilover sleeve on
    installed the shock strut
    tighten the retaining nut
    installed the spring
    installed dust boot
    installed the top hat
    installed x3 washers
    installed the IE camber plates( http://www.iemotorsport.com/bmw/E30-...0cambersr.html )
    installed the washer
    tighten the new nut
    EX: http://garagistic.com/uploads/images...esized/22a.JPG
    ...except I ran camber plates after top hats
    I am also hearing like a clunking noise when I hit a bump/when suspension travels. That normal for camber plates maybe? Any idea of what's going on? Thanks in advance!
    Originally posted by einstein57
    You would not have to mod anything. Cutting off the factory lower perch would be optional for easier adjustability.
    This would be the lowest setting. Please note this is an early model with high arches
  • GUERONASTY
    • Aug 2011
    • 811
    ...I did try contacting "einstein57" but his inbox is full
    • reelizmpro
      • 9552
      Install only 1 adjuster ring (all the way down anyway) and use a 5" spring. This will get you low without cutting the spring perch.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • GUERONASTY
        • Aug 2011
        • 811
        Yeah I was thinking it was going to be that but after I saw einstein57's post on how low it was with nothing cut I thought it be the same. Could have swore he said it was on a 6" spring as well but I may be mistaking. Gonna drive it for a bit and see if it settles down more, hopefully! Then take everything apart again ughh and remove that one lovely adjuster. Any idea what noise is???
        • GUERONASTY
          • Aug 2011
          • 811
          Seems i figured it out...
          This is a rode less traveled. I'm not going to give away my trade secrets on how i shortened the bilstein sports. Every part of my coilover setup is offered for sale by me.
          First we shorten the strut tubes 1.9" and add a collar along with AKG sway link tabs. Welding done by Chris Castro of Castro Motorsports.
          Pics installed with my GE camber plates and coilover dust boots. 6" #300 springs
          Rear installed with GE tall RSMs 4" #800 springs (14lbs of boost and a stereo system makes the car squat hard)
          Rear all the way down and fronts all the way up. Will be switching to 7" springs
          • GUERONASTY
            • Aug 2011
            • 811
            ...now I need to figure out if the noise is normal with camber plates. Anyone?
            • einstein57
              • Jun 2007
              • 10780
              Garagistic has lower front spring rates. You should be able to get lower then 1.5" of tire gap but you have different camber plates then i was offering. I was offering the race plates. The springs will settle a little less then a half inch. Here is mckmans car with 6" 450 and no cutting (other then factory perch removal). He is even running undersized tires. He is running his perches upside down to get an extra 1/2" of drop.
              www.gecoils.com
              • GUERONASTY
                • Aug 2011
                • 811
                Factory purch removal it is then. Are you still offering that service? If so how much?
                • noE30
                  • Jun 2008
                  • 2260
                  The noise from the camber plates is common. Reread the group buy thread, many of us had issues with it. I solved mine by adding grease to the race plate bearings and tightening the top shock nut with the suspension out of the car. If you do it while installed there is a chance that its not lined up correctly.
                  Flickr
                  @michael.colby on Instagram
                  "All he needed was a wheel in his hand and four on the road"
                  • einstein57
                    • Jun 2007
                    • 10780
                    All you need is a cheap harbor freight sawzall or cut off wheel to remove the factory perch. I was offering sectioning services for people who wanted to run shorter inserts. Or are you talking about welding on a new perch in a lower position? If so 90% of the work is grinding off the old weld. Probably not worth your gas to have me do it. You could grind it off and have a local muffler shop weld on a new section of pipe an inch or so lower. I use black pipe for gas and water lines. IIRC it was $8 a foot.
                    Pictures of Yert318 cutting of his perches for his 745i
                    www.gecoils.com
                    • JGood
                      • Jan 2004
                      • 7959
                      Not sure if you ever got your clunk figured out, but I had a clunking with the identical setup. Turned out to be my IE plates, the spherical bearing had play within the plate that it is installed in. IE sent me a set of SUPER thin washers, which I installed between the spherical bearing and the c-clip that holds it in place. I couldn't believe it, but the clunking went away. It's hard to think that tiny bit of play could cause that much noise!
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
                      • GUERONASTY
                        • Aug 2011
                        • 811
                        I actually removed the GE coils switched to H&R race. I am on BavAuto springs in the mean time and no noise no more but I did notice the slight play you are talking about but did not hear a noise. I am gonna contact IE for those washed though. Thanks man good looking out!
