See if einstein57 can order you some 60mm Hypercoils, or go here
4in springs and raceland vs jom?
i am guessing for the fronts? and running 2.25 inch springs in the rear? There are no option for 4 inch 60mm springs2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
Seriously am I speaking in tongues or something? Lol the diameter of the JOM/raceland adjuster is 60mm... that is not 'flipped' or any other weird voodoo magic. Just the OD of where the spring sits...-AlexComment
I have 400lb front and 650lb rear
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
I'm going to order 4" springs. It should give me 2" of upward travel before the lower sleeve hits the upper mount.
As it sits right now, my 6" rear spring with the sleeve adjusted all the way down sits right about stock height. So a 5" spring will lower it 1" with no further adjustment. I'll go 4" and adjust the sleeves up to get me 1" lower. Plus the higher spring rate springs won't compress as much. I'll get one of those tender/helper springs to keep everything in the perches.1984 325e
2000 323iComment
