4in springs and raceland vs jom?
  • e^2
    • Dec 2010
    • 65
    #46
    Originally posted by E30SPDFRK
    Why does it seem the idiots all flock to suspension threads?
    It doesn't work like that. The spring sits about halfway between the trailing arm pivot and the wheel centerline, so a 5" spring with the same rate as your 6" spring should (theoretically) lower you about 2". It's not exactly halfway though, and there are other angles in play so it won't be exact, but don't think 1" at the spring equals 1" at the wheels.
    No shit sherlock. Do you want me to get into the math or do you want me to keep it simple? Every time I start to make it complicated peoples brains turn off.
    @Chris, I used a '89 camaro rear shock. They weigh a little more in the rear but that works out with the stiffer spring rates. Bolt in replacement if you get a kit with the camaro rear bolts (they are metric).
    1984 325e
    2000 323i
    • CHIF8008
      • 3447
      #47
      Originally posted by ak-
      if you intend to use these waffleswaffleswaffleswaffleswaffleswaffles adjusters.
      truth. over time mine got so loose that the collars slipped threads and caused the spring to sit cock-eyed. go with a "square cut" threaded adjuster if you ever plan to buy other ones
      -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
      -The Beauty in the Tragedy-
      MECHANIC SMASH!!- (you all know you do it)
      Got Drop?? ;-)
      But of course
      E30s are know to be notoriously really really really ridiculously good looking
      • Stephen
        Шлем ишака
        • 10774
        #48
        A 4" spring with no adjuster will have the trailing arms bottomed out. If you want to go that low, it is a nessecity to trim the spring centering nubs like Chif said.
        At what rate?
        I run a 4" 600# without adjuster, but with spring pads and do not bottom out on the arm. Removed pads made for basically no travel of shock, didnt check arm clearance.
        • ak-
          • 12422
          #49
          Originally posted by Stephen
          At what rate?
          Haha, you'd probably hear the clearance first.
          1991 325iS turbo
          • Stephen
            Шлем ишака
            • 10774
            #50
            I know it wasnt bottomed out completely, i wouldve felt that lol. It was just 0 shock travel on bilstein feels.
            • Chriskbmx
              • Apr 2012
              • 972
              #51
              haha i will get other adjusters in the future for sure, but if it works out i might just use the original spring pads and just he spring.
              • E30SPDFRK
                • 5716
                #52
                Easy there tough guy, you're the one who posted wrong or misleading information. Half the people in this thread already don't have a brain it seems, so why go posting wrong information and confuse them more?
                At what rate?
                I tried with 800lb and no pads and it was bottomed. I wouldn't think the pads make that much of a difference but they could.
                And it is impossible to bottom out a Bilstein in the back. You can remove the spring and jack up the trailing arm till it touches the body and still unbolt the shock and move it up more.
                Byron
                Leichtbau
                • CHIF8008
                  • 3447
                  #53
                  im running the camaro AGX adjustables in the rear. kinda wish i went with even a shorter shock if what your saying is true about the bilsteins
                  Got Drop?? ;-)
                  But of course
                  • Stephen
                    Шлем ишака
                    • 10774
                    #54
                    800 is stiffer, so compressed length would be longer. That and pads probably make up the differnce.
                    I can recheck, but i was hitting bumpstop not arm. I'm 100% positive. Bilstein bumps are just a dense foam, so just because there is negligible movement doesnt mean you're not out of stroke and in the bumpstop. They are also out of the shock's usable stroke regardless of trailing arm. I have some old bilsteins this happened on, and the shock was so fucked up swapping out to proper ones actually allowed the rear to settle maybe a half inch.
                    • E30SPDFRK
                      • 5716
                      #55
                      Did you have an external bumpstop? I could push it up by hand probably .5-.75" before it got too hard to push.
                      Byron
                      Leichtbau
                      • Stephen
                        Шлем ишака
                        • 10774
                        #56
                        Dont believe so but its been a while. Ill look next time my cars up in the air, youve got me wondering now
                        • einstein57
                          • Jun 2007
                          • 10780
                          #57
                          No you don't need to cut the metal nub if you use a 4" with the adjuster and don't cut it regardless, wow.
                          And no it is not going to fit the rear JOM adjuster unless you unscrew the collar, flip it, and screw it back on to the sleeve. I'm telling you this because this is what I have on MY car. 4" 750lbs Hypercoil on the JOM flipped adjuster late model car.
                          I'm a half inch away from tucking the rim and am limited by the flipped adjuster (as I've mentioned beforehand). Considering you ordered 600lbs springs, yours will sag more when maxed out if you intend to use these waffleswaffleswaffleswaffleswaffleswaffles adjusters.
                          I thought you had 2.25" springs. That would make more sense considering hypercoil does not have a 750# 4" spring with a 2.5" I.D. in their catalog. :giggle:
                          www.gecoils.com
                          • ak-
                            • 12422
                            #58
                            I do have 2.25"s
                            I think I see the confusion. I didn't see where the OP was asking if 2.5" would work instead and I kept rambling how to make 2.25"s work.
                            1991 325iS turbo
                            • Chriskbmx
                              • Apr 2012
                              • 972
                              #59
                              it is all good my friend. i got the 4inch springs and they arrived at my door, this weekend we will see how they look!
