Anyone else rubbing on this?
  • Jordan
    • 12916
    I've whacked this lip/stud a couple times. Makes a pretty annoying noise.
    Is anyone else low enough to rub on this crap? Next time I've got time I'm gonna pull both front wheels and hammer that lip over flat where the tire can strike it.
    No damage to either front tire, just little marks on the surface of the rubber you wouldn't ever notice unless you knew what you are looking for.
    Both time's I've hit it were on really rough bumpy roads hauling ass.
    https://mtechniqueabs.com/
  • 92 mtechnic cabrio
    • 4907
    stud's gone, lip's gone.
    self-clearance FTW
    just kidding, I hammered the lip and pulled the stud.
    R.I.P 07/01/09 - 04/23/10 :(
    • rwh11385
      lance_entities
      • 18403
      if you had shorter springs, your perches wouldn't be slammed all the way down....
      • skatefreak
        • Jan 2006
        • 116
        I hit it alot drifting!! It does some real bad things when it happens. I need to get rid of it.
        • Jordan
          • 12916
          and if I didn't have the perches adjusted all the way down as low as they would go the car wouldn't be slammed all the way down either...
          I don't see how your above statement has any bearing in the context of this thread.... ?
          • 2002maniac
            • 4260
            your springs are too soft.
            • Jordan
              • 12916
              lol. No, just too low.
              • Axxe
                • Aug 2004
                • 3355
                Ricer.
                Keep it slideways!!
                • rwh11385
                  lance_entities
                  • 18403
                  i thought you were talking about the adjusting collar lip, but nevermind. if you had an inch shorter spring, the collar could be an inch higher and overall ride height would remain the same in the front, fyi.
                  you need stiffer springs
                  and your car will probably handle like shit being that goddamn slammed and mexican ghetto ride height.... ridin on bumpstops all the time. good luck. ricer.
                  • Digitalwave
                    is a poseur
                    • 6299
                    Jordan's rates are plenty stiff, he just has huge tires. I am pretty sure he never bottoms out. My car is close to as low as him and I have soft springs and it takes a lot to bottom out.
                    RISING EDGE
                    • Jordan
                      • 12916
                      I definately don't bottom out. The camber plates give me plenty of real suspension travel. Obviously I'm not bottoming out if I manage to slam the tire against the unibody.
                      • rwh11385
                        lance_entities
                        • 18403
                        um, Teej, i don't see the comparison is that valid as you have progressive and GC's have linear. Your springs stiffen as they compress, versus ours which don't.
                        • Digitalwave
                          is a poseur
                          • 6299
                          His constant rate is still stiffer than my springs stiffest rate. If mine don't bottom, I doubt his does.
                          RISING EDGE
                          • rwh11385
                            lance_entities
                            • 18403
                            And slamming into the unibody is really good for handling...
                            I'd rather have undersized boys like Andre as opposed to big ole tires (if Teej is right) when slammed.
                            another solution is to park the "THE CLEANEST, well modded e30 on CarDomain" and try to win some trophies at carshows, as opposed to driving it recklessly on the streets and finding out how much your FORM precedes the FUNCTION!
                            • Jordan
                              • 12916
                              lol. Well TJ is right about the front tires, they are a e36 size. 225/45R17.
                              245/40R17 will be all around soon, and should not rub up front on that shit anymore. Either way I'm gonna fold that lip over and break the copper stud off for more clearance.
                              and Heeter. Its just a car.
