GC setup+front top camber plate requirement
  • IronFreak
    • Dec 2012
    • 3702
    #31
    Of course they will fit the stock housing, but the body of the shock is shorter. Also the valving is different. You have to space up the sport shock, just like you do the ix shock in the housing the make sure the locking nut does it's job correctly.
    Instagram @rebellionforge
    • IronFreak
      • Dec 2012
      • 3702
      #32
      The whole argument can be a convoluted mess. I will stop talking because I'm getting multiple sources claiming different things. Plus I use Koni so I don't really care haha.
      • Mr. Burns
        • Aug 2011
        • 3516
        #33
        Since its proven, that's what I'm ordering. Boom done.
        This better fix this lol.
        Originally posted by flyboyx
        i have watched my dog lick himself off a few times
        • IronFreak
          • Dec 2012
          • 3702
          #34
          What did you order?
          • Mr. Burns
            • Aug 2011
            • 3516
            #35
            Originally posted by IronFreak
            What did you order?
            Koni indicates as these being cabrio specific, and compatible with C/O's....
            86-2277
            • IronFreak
              • Dec 2012
              • 3702
              #36
              Nice!
              • Northern
                • 5095
                #37
                Body of the shock is shorter. But the sleeve is the same length as an oem shock so it fits in the strut housing with no spacer. I've always heard that the hd and sport rates are the same. The ix hd insert is physically shorter.
                Originally posted by priapism
                Originally posted by shameson
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  #38
                  forgot to update this-
                  installed the Koni's up front, no camber plates and resolved the problem.
                  supah toight now.
                  one complaint about the koni's...
                  "adjustable"...right.
                  you need to yank out the entire struts, and adjust...it's not like some other koni adjustables that are simply done at the flick of a knob.
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #39
                    supah toight now.
                    say whaaaaaaaaaa!
                    Seriously? I wonder if vert shocks are different. I run 5-lug now but the 4-lug konis I had were top mount adjustment......
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      #40
                      I guess they are...
                      it's kind of a drag...you need to remove the entire assembly in order adjust rebound.
                      All the other Koni's I've seen, and have owned have all been externally adjustable...Koni calls this "standard adjustable"
                      pretty ghetto for the amount of $$ you pay for them IMO
                      it's not really clear when you order them, I thought all Koni yellow where externally adjustable...
                      • nrubenstein
                        • 3148
                        #41
                        You bought the shitty kind of Koni, then. Plenty of E30 fitment Konis out there that are top adjustable.
                        Of course, you could have simply trimmed the internal bump stop in the Bilstein. And yes, camber plates at the SAME ride height would have improved things as well. Depending on the design of the plate, you might have needed to switch to longer springs in order to achieve the same ride height without running the risk of blocking the springs.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          #42
                          I went by the book and ordered the cabrio specific konis.
                          Had I of known otherwise, I wouldn't of gotten these.
                          Oh well ..At least my slamming/bottoming out is resolved...although I do feel a bit taken If anything.
                          • Mr. Burns
                            • Aug 2011
                            • 3516
                            #43
                            Oh and fwiw, the billsteins I pulled out were blown.
                            Very blown.
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #44
                              Did you say they were new?
                              I have used sports and just ordered gc coilovers with a higher spring rates than you.
                              I have a feeling im going to have the same issue
