What dust boots for coilovers?
  • kronus
    • Apr 2008
    • 13032
    The stock dust boots I get with bilstein sports don't fit nicely inside typical 2.5" coilover springs. What do people typically do for dust boots? Is there a common alternative? I'd rather not run without.
    cars beep boop
  • IronFreak
    • Dec 2012
    • 3702
    That's a good question, I figured there wasn't one. most of the coilovers I have seen don't run any....
    Instagram @rebellionforge
    • SkiFree
      • Jun 2011
      • 2766
      I have yet to find one that fits well, there are some that almost do it properly but get hung up just a little on the spring ID.
      EDIT. found one.
      ADAMS Autosport
      • Northern
        I like cupcakes & sh!tboxes
        • 5251
        The ones that came with the ge kits fit with lots of clearance, no idea what theyre from, but im sure nigel knows.
        Originally posted by priapism
        Originally posted by shameson
        • bimmerboy4444
          • Apr 2013
          • 62
          motto cross shock boots thats what i did when my new rear shocks didn't come with dust boots. thar should be a set skinny enough to fit in to 2.5in springs. just cut it down the right length zip tie in place. DONE
          • einstein57
            • Jun 2007
            • 10780
            They are from bilstein. I'll be ordering more soon.
            www.gecoils.com
            • kronus
              • Apr 2008
              • 13032
              can i get uh.. six
              cars beep boop
              • einstein57
                • Jun 2007
                • 10780
                Sure. I deleted most of our PMs but i have been putting blems to the side for you guys.
                www.gecoils.com
                • SkiFree
                  • Jun 2011
                  • 2766
                  E21 power steering rack center boots.
                  ADAMS Autosport
                  • Cletonius
                    • 2809
                    I reused my OEM dust boots over the rear shocks. Cut them off the old shocksand used a ziptie to secure them on the new ones. Konis are slightly smaller diameter so they overlapped a bit.
                    I picked up some dernier nylon and Velcro to make covers for my adjusters. I'll post a thread eventually once I get them made up.
                    - Josh
                    1990 325is
                    Need a shift boot?
                    Looking to buy shift boot frames, PM if you have one to sell
                    Here's what happens when you let the internet pick your license plate
                    • digger
                      • Nov 2005
                      • 6169
                      Do people reuse OEM rear shock boots for Koni SA and poly RSM? ones i got are 12mm thread shaft
                      ive seen some cars that look like they dont use a boot at all ?
                      EDIT: incase others wanted to know you can indeed enlarge the 10mm hole in the stock ones to 12mm and use the original boots.......
