Forward mounted front sway bar
  • E30_fiend
    • Apr 2006
    • 7348
    Ive been thinking about this for quite some time now. I need to revisit this idea...
    Taylor
    • IronFreak
      • Dec 2012
      • 3702
      Originally posted by Eric
      I'm not worried about the sump, just want to correct the exhaust flow of that one header bank.
      What I meant is I'm not sure where you would cross over in front of the subframe. Unless you could somehow squeeze it in that same gap area as the steering rack behind the sump. Unless you made a custom one like I posted earlier and mounted it further foward like so......
      Instagram @rebellionforge
        • 34830
        there are longer swaybars that would reach - E46 etc.
        • IronFreak
          • Dec 2012
          • 3702
          Are the IE and other aftermarket sways made out of high carbon steel? I wonder if you couldn't just take your stock sway, flip it around and weld extensions onto the ends the reach the point that you wanted. The lower relief area on the stock bar would give you that added clearance area for the lower crank pulley. As you suspension flexed it would move away from the oil pan towards the front of the car.
            • 34830
            they are made of spring steel.
            not really a good idea to weld onto it, but it can be done.
            the E46 swaybar ends are probably 4-5" longer.
            • IronFreak
              • Dec 2012
              • 3702
              Is the width going to be the same? Seems like the e46 is a wide car, then again I'm not at all familiar with them. I was thinking about just ordering some chromoly tube and building one. you can get 7/8 - 1" piece about 3' long for $15-$20. Weld on the arm length of choice and boom. done. Energy suspension sells sway mounts in about every size you'd ever want.
                • 34830
                Its pretty close to the same size as an ix bar.
