swaybar bushings, links, etc
  • wastedincome
    • Aug 2004
    • 906
    While my cabbie is hibernating this winter I'll be replacing much of the suspension, mounts, bushings, etc with mainly all upgraded parts.
    I'm not sure what to do when it comes to my sway bar mounts and end-links. For now I will be keeping the stock sways but want to upgrade the hardware if I can. IE's rear mounts seem great cause they will give what ever size bushing you need. What about the front and endlink??
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
  • wastedincome
    • Aug 2004
    • 906
    bump for the morning crowd ;)
    CURRENT STOCK LIST:
    • Digitalwave
      is a poseur
      • 6299
      If you are using OEM sways I'd think the stock links are just fine.
      RISING EDGE
      • wastedincome
        • Aug 2004
        • 906
        Thanks, I have considered swapping out my rear for a M3 one though. Since its a cabby I allready have the biggest stock front bar made
        CURRENT STOCK LIST:
        • Digitalwave
          is a poseur
          • 6299
          I'd say you are fine with an M3 bar and stock links (M3 links with a larger bushing) as well.
          RISING EDGE
            • 34844
            M3 rear links are the same as any other E30 anyway...
            • Digitalwave
              is a poseur
              • 6299
              I was unsure, didn't think an thicker M3 bar would fit in the smaller bushing for a 325i link. Must taper the bar down at the ends.
              RISING EDGE
