How to add more negative camber to the rear?
  • bigredguy
    • 357
    thanks alot for the help. I am looking into the eccentric rtabs, and the camber and toe correction kits. When you guys say position the plates lower I am a little confused. I am new to the whole idea of adding camber in the rear so I do apologize. If anyone has a picture of how a trailing arm looks stock and one that is modified that would greatly help.
    also is there a difference between the camber and toe correction kits and the eccentric rtabs? what about a price difference?
    INSTAGRAM @ merlow_
    • Todd Black 88
      • Oct 2007
      • 3449
      The eccentric rtab's are garbage. They will change position over time and throw out your allignment.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • bigredguy
        • 357
        alright thanks for that. so really the way to go is the weld in camber and toe correction kits?
        INSTAGRAM @ merlow_
        • AndrewBird
          The Mad Scientist
          • 11898
          Originally posted by jlevie
          Since increasing camber requires the inner trailing arm to go down, there is a limit to how much camber you can get by positioning the plates lower. But you can get all you could want by having a frame shop bend the arms.
          Couldn't you make the outer trailing arm mount go up to increase camber?
          • JonnyOg
            • Sep 2012
            • 191
            Dont IX subframe bushings space the subframe down for more camber? You could try that.
            • bigredguy
              • 357
              any more info on the iX subframe bushings? This could be a good way if not Ill have to spend the money on the weld in tabs
              INSTAGRAM @ merlow_
              • TobyB
                • 5296
                Old post, I know, but there's surprisingly little on this.
                Yes, there is room on the outer point to raise it maybe 3/4"". That'll gain a solid,
                what, couple of degrees. Also
                this, and it will give you additional room to move the outer point up.
                This will, of course, make the rear have no grip whatsoever, as the car will
                be running on the inside edges of the tires, but that wasn't the OP's question or concern.
                Or it will let you run a 225 tire on a 6" rim on the track. When you'll NEED -6 degrees
                of camber!
                t
                • DER E30
                  • Sep 2013
                  • 2349
                  Need pics of the set up, the wheels and fitment...
                  -Christian
                    • 34844
                    install ix subframe bushings. that'll give you about 1/2 degree more and is relatively simple.
                    aside from that are eccentric trailing arm bushings.
