Is anyone (besides the dude that works at MCS) running MCS coilovers?
  • burkey001
    • Feb 2011
    • 608
    Originally posted by Liquidity
    Those brakes gotta have the clamping force of a bench vise. Jesus.
    :) They are a little on the strong side. My own kit using Stoptech STR43 calipers and AP Racing J-hook rotors.
    Once the PFC01 pads get some temp in them it is like hitting the pause button :) A good match in overkill to the MCS dampers.
    88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
    90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
    • acolella76
      • 2950
      Mind if I ask how much a set of those brakes cost? Are you using custom hats or something off the shelf? Your car is insane!
      BTW be careful with how tight you clamp the canisters in the middle like that. The piston inside can sometimes get stuck or restricted when clamped too tight.
      -Alex
      • burkey001
        • Feb 2011
        • 608
        The brake cost.. Well they're a little OTT. They are my own creation and probably not economically viable for most E30 :)
        Pics below show the current version of the rotor hats. I intend to make a few of these kits once I'm 100% satisfied with the design & spec. We're 99% there now.
        Per below pics, the hats are 7075 T651 and the bobbins are 4340 cro mo. Hats will be anodised, bobbins will be tuftrided.
        The hats allow for radial expansion of the rotors via elongated slots in the hat itelf. The bobbins lock into the hat to allow the rotor to be attached and tightened / removed with a single tool only. Hardware is 12,9 M8 SHCS. The approach taken with the bobbins is an adaption of Brembos "D type bobbin". The fronts are basically just a bit bigger than the Brembo size with a bigger lip to lock against. The rears work in reverse to allow rear float with a parking shoe (concentric to rotor, not the hat)
        The rear hats are also fully floating with a unique approach to providing float and OEM hand brake functionality.
        Front
        Back
        (rear rotors attached backwards, thanks for paying attention)
        I'll do some better pics once I get the next version done (and polished & anodised)
        thanks for the tip on the clamp, will check that.
        burkey
        • matthugie
          • Mar 2004
          • 1810
          What diameter are those rotors? That looks like an amazing kit.
          88 325is - S52 powered
          Originally posted by King Arthur
          We'll not risk another frontal assault, that rabbit's dynamite!
          • burkey001
            • Feb 2011
            • 608
            The rotors and the calipers are based around 'late model stock car' product catalogues from AP and StopTech. This is best because:
            - designed to fit in 15inch wheel
            - cheap, plentiful parts
            The rotors are 11.75 x 1.25inch
            • DER E30
              • Sep 2013
              • 2349
              Those are awesome!!:up:
              -Christian
              • vitiokas95
                • Dec 2013
                • 482
                planning on purchasing MCS set up over the winter. How did you like yours?
                1990 e30 325is S50 swap (NASA GTS2 race car)
                1990 e30 325is
                1988 e30 M3 S50 euro swap
                • burkey001
                  • Feb 2011
                  • 608
                  Worth the money, would buy again
                  • Rapid Butterfly
                    • Mar 2016
                    • 1
                    I have a set of the two way non remotes on my pro3 car. They're amazing and made a convert of this life long Koni girl.
                    Have the two way remotes now on my subie as well (nationally competitive autocross car), based on how much I loved the MCS on the e30.
                    They're worth it. Period.
                    Mina Ingraham (ICSCC / ORSCCA)
                    1986 325 (ICSCC Pro 3 # 277)
                    2004 WRX STi (STUL3) * 2006 ZX6J
                    • Digitalwave
                      is a poseur
                      • 6299
                      Any of you MCS people still around? How have they been treating you?
                      RISING EDGE
                      • burkey001
                        • Feb 2011
                        • 608
                        Still superb
                        • Eric
                          • 5142
                          Originally posted by burkey001
                          Still superb
                          How are those brakes holding up? have any more pics of them installed?
                          • burkey001
                            • Feb 2011
                            • 608
                            I find that they need stronger anti rattle clips for the pfc pads i am using. Maybe the pfc pad is slightly small but i get some pad knockback which means i need to tap the brakes before i need to brake. Which takes getting used to and not ideal. Haven't driven the car in over a year, so would like to try something stiffer / thicker just haven't got around to it 🙂
                            • burkey001
                              • Feb 2011
                              • 608
                              coupla pics
                              And a pic of the car 😊
                              • Digitalwave
                                is a poseur
                                • 6299
                                Wow, that is incredible.
                                RISING EDGE
