Comprehensive guide to extreme lowering?
  • Liquidity
    • May 2014
    • 395
    So far after a couple weeks of looking through this forum I've gathered you want for the front:
    e90 top hats
    ix front shocks
    strut tubes shortened 85mm
    short stabilizer links
    And for the rear:
    3rd gen camaro rear shocks
    offset subframe bushings
    ovaled out trailing arm mounting points
    Apart from my choice brand of springs and dampers, is there anything I'm missing?
  • Mr. Tasty
    • Jul 2011
    • 3421
    you are going to run stock springs on sectioned tubes? What's the point, just go coil over.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • Liquidity
      • May 2014
      • 395
      The only time I mentioned springs was when I specifically said I wasn't talking about them in this list. But thanks for sidetracking my thread with the very first reply. I appreciate it.
      • aPapester
        • 215
        get coil adjusters with your choice of springs and cut the spring perch down. that helps a bit
        Check Out My Photography
        aPapester Photography Facebook
        • LJ851
          • 7919
          Best mod
          Lorin
          The M30 is God's engine.
          • Liquidity
            • May 2014
            • 395
            So besides the springs, I haven't missed anything? This should allow the mechanical side of the suspension down a good 3-4" without binding anything up?
            • Mr. Tasty
              • Jul 2011
              • 3421
              you said e90 top hats, that is for stock diameter springs.
              (Daily Driver)
              KW V2 Coilovers
              • Liquidity
                • May 2014
                • 395
                Just stop. If you can't even make one on topic post, please don't bother me.
                • Dirty325ix
                  • Sep 2012
                  • 689
                  jeez you must be a complete dick in person
                  but
                  I don't thing you want the Bilstein ix HDs they suck for lowering and ix so I don't know how they will help you...look a the konis I have heard a lot of good things and they are adjustable
                  • Liquidity
                    • May 2014
                    • 395
                    Is that a joke? And once again, I never said which dampers I was gonna get.
                    What's with you guys?
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      • Tom.
                        • Sep 2012
                        • 121
                        If you section the tube (removing the stock spring perch), and weld on an after market spring perch, you'll have to use smaller diameter coil springs which won't work with e90 drop hats.
                        Which (I think) is all Cody is getting at.
                        • Liquidity
                          • May 2014
                          • 395
                          Why would I need to weld in an aftermarket perch? Is there something about the factory one that's inadequate?
                          • ak-
                            • 12422
                            85mm is too much to section out and your iX shock insert will be longer than the housings itself.
                            75mm max since that's roughly the length of the shock itself.
                            e90 hats only work if you are using stock springs on a stock perch, or tapered springs.
                            If you do intend to section the housing and use a stock perch(not sure why anyone would), you won't be able to fit any wheels as the tire will touch the perch now since you lowered it by sectioning it.
                            Cut the perch off and weld a bead around the area as a base for your coilover collar to sit on.
                            Camber plates > e90 hats. For several reasons.
                            Swaybar links are already short as can be. Idk if they come any shorter?
                            Considering the fab work, weld M3-tabs to your housings as an upgrade and "while-you're-in-there" type of deal. Much better, and then you can play with link length.
                            tl;dl: skip all of this and call BCracing and tell them you want a shorter shock setup to lower your car to undriveable heights. They are aware of current car culture and won't laugh at you - I'm serious.
                            1991 325iS turbo
                            • Liquidity
                              • May 2014
                              • 395
                              So a set of let's say IE springs won't work with an e90 top hat? Because I swear I just saw a guy who was running that exact setup.
