Q: What tool to remove strut gland nut?
  • funcrew
    • Jun 2007
    • 1223
    Pardon my stupidity, but I've never seen a fastener like this:
    What is the method to remove it? Is the flimsy plastic outer sleeve important? I don't mind buying a tool if needed, I already have 100 special tools for the E30; the engineers in the 80's just loved specialty fasteners.
    edit: Where do I get new gland nuts? Dealership? I'm installing KYB's that don't come with new gland nuts.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • Wishno87
    • 6025
    Take the rubber thing off and use a pipe wrench.
    • uturn
      • Dec 2010
      • 1008
      It should take a pin spanner. I wouldn't buy one but instead go at it with a pipe wrench and use the new gland nut that comes with the bilsteins.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        But do as the others said. Otherwise, put the old gland nut in a vice, and rotate the housing, that is IF you removed the whole thing off the car.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          Big pipe wrench. But once it is barely loose, my angle grinder wrench fits perfectly in the holes.
          In case there's someone out there who has never experienced the joy of an angle grinder:
          Originally posted by priapism
          Originally posted by shameson
          • accident
            • 7303
            I've always used big pliers or a pipe wrench. If you're upgrading to something like Bilstein the spanner for the stock gland nuts will be pointless because Bilstein uses a different gland nut.
            Moral of this story?
            • funcrew
              • Jun 2007
              • 1223
              Thanks to all for your replies. I guess I'm lucky; I tore off the plastic covers, and soaked the gland nuts overnight in penetrating oil. Couldn't find a pin spanner wrench on Sunday in Las Vegas, so got a 24 inch monkey wrench from harbor freight. Bolted the strut to a wheel, had my son stand on the tire, applied the wrench and the nut spun off with no drama whatsoever. They joys of working on a rust-free California car. Thanks again for your patience with my noob questions and issues.
              -Dr. Paul Forrester
              • Roysneon
                • 4505
                Glad I'm not the only one who immediately jumped to the pipe wrench solution.
                Originally posted by mbonanni
                I am a pursit now.
                • Cabriolet
                  • 9620
                  every car i've done. pipe wrench...
                  Much wow
                  I hate 4 doors
