Dropping the car the right way?
  • Peace_Power
    • Jul 2014
    • 77
    So I finally ordered a set of springs and shocks.
    It's Low-tech sport shocks, their upper tier shocks.
    The springs are 40/35 for a moderate drop and hopefully not too much uneven tire wear.
    http://www.ebay.com/itm/371082047159...%3AMEBIDX%3AIT
    I'll report back when I've got it all installed and have had a chance to test it properly. (=
    • 87'325e
      • Jun 2013
      • 121
      Any news. Post pics if you can.
      ^Copyright Audiwark^
      • Peace_Power
        • Jul 2014
        • 77
        Okay, so this is what it used to look like:
        And now I've got the front shocks and springs installed.
        It's about 1.75 inch b/w tire and fender in the front and with whatever springs are in the back it's 2.75 inch clearance there. It's a bit lower than it's s'posed to be as I had to re-weld the upper spring cups and that probably gave me a 1/2 inch lower car just that.
        I'm really liking the aggressive downward sloping angle of the car so I'll just keep the rear springs and install the new shocks and leave it there.
        And from the old parts there was a decent spring and a decent shock, the rest was all trash. =p So good thing I did this!
        • getouth
          • Jan 2010
          • 3343
          Nice!
          FEEDBACK:
          http://www.r3vlimited.com/board/showthread.php?t=316212
          BMWCCA #398608
          IG @yagayo38
          "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
          • Peace_Power
            • Jul 2014
            • 77
            Thanks!
            Question: In the rear there must already be lowering springs, or did they come this way stock?
            • Cabriolet
              • 9620
              Originally posted by Peace_Power
              Thanks!
              it is actually an allusion. the rear arches are lower than the front and make it look like the butt of the car is sagging.
              the rear of my car is 1.25 inches higher than the front.
              YL7A5273 by Eric Berger, on Flickr
              Much wow
              I hate 4 doors
              • Peace_Power
                • Jul 2014
                • 77
                So, just for the aesthetics I should probably stick with the stock springs. Or what do you all think looks the best?
                These 35mm springs would drop it another 1.4 inches in the rear.
                • Cabriolet
                  • 9620
                  these are what i use when not installing coilovers on e30s.
                  running the stock springs will be terrible. you will have rear end bounce like nobody's business. the brand of springs and shocks you got werent on my recommended list so im not sure of their rates and quality but i bet they wont do well if you run rear stock springs.
                  Much wow
                  I hate 4 doors
                  • Peace_Power
                    • Jul 2014
                    • 77
                    But a soft spring and a stiff shock should work all right, shouldn't it?
                    "you can be just fine with a soft spring and a stiff shock." http://mustardcat.brinkster.net/p3g/...on/FAQ/FAQ.htm
                    • Peace_Power
                      • Jul 2014
                      • 77
                      So the spring rates for the Lowtec kit are:
                      Front: 285 lb/inch progressive (106 original 325i)
                      Rear: 450 lb/inch progressive (245 original 325i)
                      Quite the difference for both the rear and front. This is definitely a no go for mix and matching springs and shock, right?
                      • Peace_Power
                        • Jul 2014
                        • 77
                        Some new pictures of the drop.
                        I really like the 40/0 drop, it just looks balanced like it was s'posed to look like this. (=
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4496
                          To me it looks like this. I'd put the rear springs in with a pad.
                          • Peace_Power
                            • Jul 2014
                            • 77
                            This explains a lot. These were my rear springs;
                            One is a BMW original, and the other is an Eibach.
                            The complete set of Lowtec springs installed. =)
                            How does that look?
