Sloppy 325is needs to get tighter
  • Mulletproofed
    • Dec 2013
    • 70
    Have a 300k 325is. The suspension is stock and super sloppy and rolls like a wave. I bought bilsteins and I think I will pair them with hr sport springs. Can someone please tell me the best bang for like 200 dollars in bushings to help the car handle tighter?? What do i prioratize? Control arm? Sway bar? Rubber shock mounts??
    318IS
    325I
    1959 Euro Bug
    87 Vert S50 5 lug
  • BMWManiac
    • Dec 2010
    • 1091
    $200 is stretching it for just control arms....and if you do control arms, you need to do the bushings.
    Sounds like you need a complete front end refresh....control arms, bushings, tie rods, sway bar bushings, sway bar end links, strut bearings.....then, you'll need an alignment.....just did this for a grand total of almost $600 with lemforder parts (I did not do sway bar bushings).
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
    • Mulletproofed
      • Dec 2013
      • 70
      Thanks for the reply. The more I looked into it, the more I see I need to pay decent money to get most of it refreshed. Did your refresh make a big difference?
      I need to decide if its worth spending that much money on a high mileage car, but here is a complete kit I found. Thoughts?
      https://www.ecstuning.com/BMW-E30-32.../Refresh_Kits/
      If I wanted to compromise, do you think this ebay kit would be terrible?
      http://www.ebay.com/itm/120764700107...%3AMEBIDX%3AIT
      Should I also get to rubber mounts for the suspension.
      Thanks for your time.
      318IS
      325I
      1959 Euro Bug
      87 Vert S50 5 lug
      • BMWManiac
        • Dec 2010
        • 1091
        I looked at those kits too. The price is very appealing, so if you can do all this yourself, I would say then it is up to you. If you are paying someone to do this, then I would buy quality parts. The ECS kit uses BMW parts for the bolts/washers (really ECS?) and URO/Vaico for the main components....I have not seen many great reviews about URO.
        As for the bay kit, again, I can't tell the brand of the parts, but guessing they are the same URO/cheap brand.
        Yes, it will make a huge difference with brand new suspension parts. The steering will feel tight and crisp!
        • noahsense
          • Nov 2008
          • 102
          Honestly, a refresh with stock parts will make the car drive wonderfully. No need for urethane this or that unless this car is track duty only.
          • ELVA164
            • 4861
            Spend the money and get good quality parts. If you don't, you'll regret it for a long time.
            • 84driver
              • Aug 2011
              • 234
              If you're going to buy a kit, Blunttech's ebay store has the best (only) deal on quality parts:
              http://www.ebay.com/itm/NEW-BMW-E30-...-/200604753588
              balticblau-metallic '84 318i 5spd 3.91 LSD
              • Mulletproofed
                • Dec 2013
                • 70
                Thanks guys. Such a freaking hard decision. I am trying to find out if you get that much more value in performance out with the money you put in....
                For example if I save a few hundred, blunt tech also put a budget kit together....
                http://www.ebay.com/itm/E30-Budget-s...f53faa&vxp=mtr
                318IS
                325I
                1959 Euro Bug
                87 Vert S50 5 lug
                • ELVA164
                  • 4861
                  This is how I see it: Suspension is a safety issue. I don't skimp on safety issues.
                  • nk1221
                    • Feb 2015
                    • 56
                    I bought the front suspension kit from Bavarian Autosport for around $225. Came with control arms/bushings, sway bar end links, and inner and outer tie rods. Car handles 100% than it did before.
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3430
                      Excessive roll points to worn out anti-sway bar links/bushings or shot rear end bushings. Nothing feels sloppier than worn out subframe bushings. $200 will probably pay for new anti-sway bar links and subframe bushings, but the time involved is significant. Having rebuilt my entire suspension setup, I'd say nothing makes a bigger difference than new rear end bushings all around.
                      IG @turbovarg
                      '91 318is, M20 turbo
